Hello Mayra,
Do you try including your Date Selector in the filter actions of your Heat Map ?
Best Regards from Venezuela !
Hello Rolando from Venezuela,
Thank you for your response.
There is no option for a Date Selector in the Heat Map actions filter.
I am noticing the same behavior. Waiting to hear back from ESRI support.
Hi @RyanStad, please let me know if they are able to find a solution. 😊
This worked for us on 10.8.1 but no longer works for us on 10.9.1. I have found that if I change the heat map symbology to a point symbology that the filter works again. But I would rather have the heat map symbology AND be able to filter it. Any updates from ESRI on this issue? Is it a known bug?
Not sure what your setup is but this is working now. I'm on 10.9.1 using a map service hosted locally with the maps and dashboard published in ArcGIS Online. Maybe try a new map and dashboard from scratch.
We are also on 10.9.1 but our feature layer is hosted on ArcGIS Server and we are using Portal / Dashboards (new). Since you are using Dashboards on ArcGIS Online I am guessing it is a newer version than Dashboard in Portal 10.9.1.
I did do a clean test where I published a new feature service then created a new map in Portal then created a new dashboard referencing the new map. The filter action is available but will not filter a heat map layer. However if I change the layer symbology to anything other than head map then the filter action will work in Dashboard.
