One of the layers in Dashboard is not filtering
2029
7
04-20-2021 11:32 AM
MayraHernandez
Hello, I created a dashboard that includes a date selector. It has several actions that filter the map layers, charts and indicators when a date is selected. I noticed that one of the layers (heat map layer) does not filter when a date is selected. The heat map layer is listed in the Date Selector “Actions” list. I noticed this happened after there was an update to the date selector.
RolandoFernandez
Hello Mayra,
Do you try including your Date Selector in the filter actions of your Heat Map ?
Best Regards from Venezuela !
MayraHernandez
Hello Rolando from Venezuela,
Thank you for your response.
There is no option for a Date Selector in the Heat Map actions filter.
RyanStad
I am noticing the same behavior.  Waiting to hear back from ESRI support.
MayraHernandez
Hi @RyanStad, please let me know if they are able to find a solution. 😊
TimothyRudzik
This worked for us on 10.8.1 but no longer works for us on 10.9.1. I have found that if I change the heat map symbology to a point symbology that the filter works again. But I would rather have the heat map symbology AND be able to filter it. Any updates from ESRI on this issue? Is it a known bug?
RyanStad
Not sure what your setup is but this is working now.  I'm on 10.9.1 using a map service hosted locally with the maps and dashboard published in ArcGIS Online.  Maybe try a new map and dashboard from scratch.
TimothyRudzik
We are also on 10.9.1 but our feature layer is hosted on ArcGIS Server and we are using Portal / Dashboards (new). Since you are using Dashboards on ArcGIS Online I am guessing it is a newer version than Dashboard in Portal 10.9.1.
I did do a clean test where I published a new feature service then created a new map in Portal then created a new dashboard referencing the new map. The filter action is available but will not filter a heat map layer. However if I change the layer symbology to anything other than head map then the filter action will work in Dashboard.
