Embedded Content in Dashboard
8047
10-24-2019 07:55 AM
by Anonymous User
Not applicable
I am trying to include the web page copied below as an Embedded Content element in my dashboard. In the Configure window, under Data Options, I chose Document and pasted the URL in the URL box. Nothing is being displayed in the content window. What could be the issue here?? Thanks!
https://www.windy.com/?26.261,-79.915,8
DerekLaw
Esri Esteemed Contributor
Hi Irena,
Just to add onto Eric's post, you would simply extract the URL from the HTML code; so from his example, simply use
https://embed.windy.com/embed2.html?lat=33.358&lon=-111.764&zoom=7&level=surface&overlay=wind&menu=&message=&marker=&calendar=&pressure=&type=map&location=coordinates&detail=&detailLat=33.355&detailLon=-111.763&metricWind=default&metricTemp=default&radarRange=-1" frameborder="0">
(basically remove the iframe tags)
You can generate the HTML code directly from the Windy.com site:
1. Click the share button next to their search bar
2. Then click weather radar or Animated map
3. You can copy the HTML code from the lower left of the dialog
Hope this helps,
AdrianWelsh
MVP Honored Contributor
Irena,
This likely has to do with how the URL is configured. I'm guessing that having commas in the URL is causing the issue (that or maybe negative signs). You likely will need to set up a URL parameter that includes those coordinates which will eventually get tacked on to the back of the root URL.
URL parameters—Operations Dashboard for ArcGIS | Documentation
Make your Dashboards more Dynamic using URL Parameters
I'm tagging Derek Law‌ and Sandra Luken‌ on this to make sure.
EricShreve
Irena Householder‌ You will need to configure the Windy.com content to a web server. Check out the example HTML Code that I have below.
<iframe width="100%" height="100%" src="https://embed.windy.com/embed2.html?lat=33.358&lon=-111.764&zoom=7&level=surface&overlay=wind&menu=&message=&marker=&calendar=&pressure=&type=map&location=coordinates&detail=&detailLat=33.355&detailLon=-111.763&metricWind=default&metricTemp=default&radarRange=-1" frameborder="0"></iframe>
DerekLaw
Hi Irena,
Hope this helps,
by Anonymous User
Not applicable
This worked, thank you all!!
