Joining two Feature Sets together and getting a count with an Arcade Data Expression
6726
12-07-2021 11:04 AM
Labels (2)
by Anonymous User
Not applicable
6 2 6,726
The Scenario:
This scenario uses Arcade to join two datasets with a data expression and return a count of joined features:
  1. A hosted feature service of "Zones"
  2. A hosted feature service of survey data that shares a common ID with the Zones in a 1-M relationship.
Important note: This workflow was designed for use cases with a small number of zones (<15). Growing beyond this number may result in slow loading times for your widgets.
The Datasets:
Zone Polygons
ZoneIDZone Name
0001North
0002West
0003South
Survey Data
ZoneIDSubmitter Name
0001Mark
0001Amy
0002Bob
0002Jared
0002Jhonatan
The Expression:
//Bring in both feature sets for the join
var zoneFS = FeatureSetByPortalItem(Portal('https://arcgis.com'),'726b8daa3a424eee94726d08487bcd86',0,['ZoneID'], true)
var surveyDataFS = FeatureSetByPortalItem(Portal('https://arcgis.com'),'544bd653c91d4920bfe184b572758af1',0,['ZoneID','SubmissionName'], false)
var joinedDict = {
  fields: [
    { name: "ZoneID", alias: "ZoneID", type: "esriFieldTypeString"},
    {name: "Registrants", type: "esriFieldTypeInteger"}
'geometryType': 'esriGeometryPolygon',
'features':[]};
var i = 0;
//for each zone in the Zone layer, count the number of records with the same ZoneID in the survey submissions
for (var t in zoneFS) {
    var tableID = t["ZoneID"]
    var tableCount = Count(Filter(surveyDataFS,"ZoneID = @tableID"))
    joinedDict.features[i] = {
        attributes: {
            ZoneID: tableID,
            Registrants: tableCount
i++
// Return dictionary cast as a feature set
return FeatureSet(Text(joinedDict));
The Result:
ZoneIDRegistrantsFID
000120
000231
000302
Modified from: https://github.com/Esri/arcade-expressions/blob/master/dashboard_data/JoinLayerFieldsToTable
2 Comments
PeterMilenkovic
Excellent code.
NorthSouthGIS
I was inspired by your code. I am trying to take advantage of new data expressions in Dashboards to essentially denormalize a table of work history related back to a tree feature. I am having trouble with my code though - the performance is extremely slow. Any suggestions?
// Get the related work orders
var includedFields = ['ServiceDate','StartDate','Status','completion_date','Price','Type','Client','TreeID'];
var includedTreeFields = ["Client","Tree","TreeID","BotanicalName","BotanicalID","CommonName","StreetNumber","StreetAddress","OnAddress","Parkway","Fictitious","OUL","Clearance","DBH","Maintenance","VisualCondition","VisualConditionNotes","RemovalPriority","HardscapeDamage","HardscapeDamageExtent","Date_Collected"]
var treeFS = FeatureSetByPortalItem(Portal('https://www.arcgis.com'), '12345',0,includedTreeFields,false)
var workFS = FeatureSetByPortalItem(Portal('https://www.arcgis.com'), '67890',2,includedFields,false)
var workFSFields = Schema(workFS).fields;
var treeFSFields = Schema(treeFS).fields;
var fieldsCombined = [];
for (var y in workFSFields){
  Push(fieldsCombined,workFSFields[y])
for (var x in treeFSFields){
  Push(fieldsCombined,treeFSFields[x])
var i = 0
var joinedDict = {
  fields: fieldsCombined,
  'geometryType': '',
  'features':[]
var combinedAttributes = {};
for (var workFeature in workFS) {
  var relatedTreeFeature = First(Filter(treeFS, "GlobalID = '" + workFeature.TreeID + "'"));
  var workAttributes = Dictionary(Text(workFeature)).attributes;
  var treeAttributes = Dictionary(Text(relatedTreeFeature)).attributes;
  for (var field in workAttributes) {
    combinedAttributes[field] = workAttributes[field];
  for (var field in treeAttributes) {
      combinedAttributes[field] = treeAttributes[field];
  joinedDict.features[i]={
    attributes: combinedAttributes
  i++
