ArcGIS Business Analyst Blog
Other Boards in This Place
Latest Activity
(77 Posts)
LaurynCarey
The next update of ArcGIS Business Analyst Pro is planned for May 1st, 2025. Below are the planned updates. Please note that all planned updates are subject to change; check back to stay apprised of the latest news.
 Our What’s New blog article and documentation will provide a comprehensive list of enhancements.
Updates to color-coded layers
  • New bivariate colors and graduated colors symbology types will allow you to see the relationship between two variables.
  • Geography levels will be displayed as interactive lists, making it easier to update the map. 
  • When using the online Esri 2024 data source, geography levels will be organized in groups by relative topic, such as groups containing levels for administrative or marketing purposes.
  • The standard deviation classification method will be added as the default variable type for averages, percentages, indexes, and ratios.
Improvements to benchmark comparisons workflow
  • New comparison methods will be included to analyze the distribution of datasets. You will be able to use the top and bottom, high to low, and above and below benchmark methods.
  • The Results pane will be enhanced with thematically colored records to show data rankings and groupings that sync to a color-matched map layer.
  • The export to Excel option will be enhanced to support exports of thematically colored cells.
  • Adding neighboring geographies to the analysis will be improved with site filtering. 
Updated suitability analysis workflow
  • Suitability analysis will be updated so users can set up and run the analysis without opening individual geoprocessing tools, allowing for uninterrupted interaction with criteria and settings.
  • You will be able to reorder criteria in the suitability analysis.
  • Exploring a statistical overview in the Results pane's summary view will now be possible. 
  • You will be able to easily undo or redo criteria modifications in the workflow.
Updates to territory design
  • The Modify Territories pane will include enhanced tooltips to display territory violations, such as attribute and distance constraints.
  • You will now be able to undo or redo manual territory edits or entire solve operations.
Enhancements to the Results pane
  • The Results pane will be updated to support interactive selections and descriptive statistics.
  • Summary, histogram, and scatterplot views will be added to benchmark comparisons. 
Data browser improvements
  • Working with variables will be improved, allowing easier ways to manage and reorder variables in lists.
  • You will be able to set favorites and view metadata pop-ups within tools and workflows.
  • A node will be added to the data browser that conveniently lists all variables in a dataset. 
  • Semantic search will be improved when working with numeric concepts. 
Updates to working with segmentation data
  • The color-coded layer workflow will apply pre-defined cartographic styles to segmentation data, such as Tapestry Segmentation data in the U.S. and PRIZM data in Canada.
  • You will be able to display segment names as IDs, or IDs and names. 
 Editor's Note: This article title and content has been updated as of 4/22/2025 to reflect the change of release availability from 4/24/2025 to 5/1/2025
Additional resources
 We’re so happy to share this upcoming release of ArcGIS Business Analyst Pro with you! For more information, check out the following resources:
more
5 0 471
Liz_esri
Watch this webinar hosted by Esri solution engineers in the Mid-Atlantic Region
Read more...
more
1 0 240
Liz_esri
Esri’s U.S. Market Potential data, updated annually, provides insights into consumer behaviors, preferences, and demand for thousands of products or services such as gift cards.
Read more...
more
0 0 193
Liz_esri
Understanding urbanicity can provide valuable insights into people’s behaviors, shopping habits, and more. Discover how Esri's newly released urbanicity data offering can benefit your work.
Read more...
more
1 0 269
FizzaChaudhry
The ArcGIS Business Analyst Pro release is planned for November 7 and we have some exciting new updates!
Read more...
more
3 0 740
FizzaChaudhry
US data compatibility packages for ArcGIS Business Analyst Desktop are being deprecated. The last data compatibility packages for Business Analyst Desktop were released in November 2023. We highly recommend you transition over toBusiness Analyst Pro to gain access to the latest data updates.
Read more...
more
3 0 1,118
ChristyDeBernardi
The ArcGIS Business Analyst Pro November 2023 release is coming! With this release, we’ve added new features for building and editing reports and infographics, accessibility improvements and much more!
Stay tuned for our upcoming What’s New blog next month, where we take a deeper dive into each of the new updates in ArcGIS Business Analyst Pro!
Business Analyst Pro Extension
  • You can build and edit infographic and classic report templates in ArcGIS Business Analyst Pro using a local dataset. Additionally, custom reports authored in ArcGIS Business Analyst Desktop can be edited and run in ArcGIS Pro.
  • The reports generated by the Target Marketing workflow were redesigned to support infographic-style elements such as interactive charts, dynamic text, and filtering.
  • The Target Marketing workflow includes accessibility enhancements. For example, keyboard navigation has been improved for the Four Quadrant Analysis chart, and the workflow has been optimized for users of screen readers.
Territory Design
  • The Assign Territories pane is now the Modify Territories pane. The pane was redesigned to include support for locking and unlocking territories, viewing base feature attributes, and other common territory management capabilities.
Geoprocessing Enhancements
  • Generate Grids and Hexagons—You can output the centroids of each grid or hexagon cell as a point layer.
Additional Resources
We’re so happy to share this release of ArcGIS Business Analyst Pro with you!
#ArcGISBusinessAnalyst #businessanalyst #esri #announcements
more
2 0 684
SarahDavid
Customized attractiveness variables and units in a Huff model empower businesses to make data-driven decisions.
Read more...
more
1 0 704
127 Subscribers
