Trying to overwrite/update a feature layer using json from an api
3886
11
07-02-2024 08:03 AM
GIS_utahDEM
I am trying to automate updates to a polyline hosted feature layer in AGOL using an API. I think I have the format of the json to update correct, however, I'm having trouble with the final step of pushing the updates to the existing hosted feature layer (line 39).
# Main function to fetch API, decode polylines, and publish to ArcGIS Online
def main():
    # Make request to API
    response = requests.get(api_url)
    if response.status_code == 200:
        # Assuming API response is JSON with 'features' containing polyline data
        features = response.json()
        # Extract features from the API data
        #features = api_data.get('features', [])
        #if not features:
        #    print("No features found in API response.")
        #    return
        try:
            # Truncate existing features in the feature layer
            feature_layer.manager.truncate()
            # Prepare new features to add
            geojson_features = []
            for feature in features:
                encoded_polyline = feature.get('EncodedPolyline')
                description = feature.get('Description')
                if encoded_polyline and description:
                    # Decode polyline from 'EncodedPolyline' field
                    decoded_polyline = decode_polyline(encoded_polyline)
                    # Convert to GeoJSON Feature format
                    geojson_feature = to_geojson_feature(decoded_polyline, description)
                    geojson_features.append(geojson_feature)
            # Add new GeoJSON features to the feature layer
            print(json.dumps(geojson_features))
            result = feature_layer.edit_features(adds=json.dumps(geojson_features))
            print(f"Features updated successfully in ArcGIS Online hosted feature layer.")
        except Exception as e:
            print(f"Failed to update feature layer: {str(e)}")
    else:
        print("Failed to fetch data from API.")
This is what the print(json.dumps(geojson_features)) returns:
[{"type": "Feature", "geometry": {"type": "LineString", "coordinates": [[40.77248, -111.8377], [40.77254, -111.83776], [40.7728, -111.83804], [40.77248, -111.8377]]}, "properties": {"Description": "Blue Detour"}},
***I removed most of the coordinates for simplicity, and only included the first feature, the rest of the features have the same format
This is what is returned for the feature_layer.edit_features(adds=json.dumps(geojson_features))
pass in features as list of Features, dicts or PropertyMap
Parameters not valid for edit_features
EarlMedina
You are passing in a string when you use json.dumps. Try this instead and see if it makes a difference:
feature_layer.edit_features(adds=geojson_features)
GIS_utahDEM
When I swap that out, I get the following error:
Failed to update feature layer: Cannot perform operation. Invalid operation parameters.
'adds' parameter is invalid
Object reference not set to an instance of an object.
(Error Code: 400)
@EarlMedina
EarlMedina
Ah, sorry I think I missed before that you were appending GeoJSON features. I believe you have to convert to esri json format. Something like this:
   "attributes": {
    "a": 1,
    "b": 1970.0,
    "c": 1.0,
   "geometry": {
     "paths": [
[-97.06138, 32.837],
[-97.06133, 33.836],
[-98.2, 34.834],
[-97, 40]
"spatialReference": {"wkid": 4326} }
You may refer to this documentation to get a sense of the geometry format you need: Geometry objects | ArcGIS REST APIs | ArcGIS Developers
GIS_utahDEM
Thank you -- I think I'm getting closer but I'm still having some difficulty. I've transformed to the appropriate format (I think), and I eliminated the attributes/ids for simplicity for now, but I am still getting an error. The format that I get which I'm trying to use in the .edit_features(adds=) is:
{'geometry': {'hasZ': False, 'hasM': False, 'paths': [[(40.77248, -111.8377), (40.77254, -111.83776), (40.7728, -111.83804), (40.7728, -111.83804), (40.77248, -111.8377)], [(40.76466, -111.84503), (40.76455, -111.84494), (0.76478, -111.84513), (40.76466, -111.84503)], [(40.76418, -111.8268), (40.76413, -111.82683), (40.76417, -111.82681)]], 'spatialReference': {'wkid': 4326}}}
 With this I get the error:
Failed to update feature layer: 0
Maybe the issue is coming from me using the .decode() method from the polyline library to return my paths?
 @EarlMedina
EarlMedina
Possibly? It looks like it might be getting confused about the tuples in your coordinates:
[[(40.77248, -111.8377)...
Replace all parentheses with the corresponding open/closing square bracket and I think you should be close.
GIS_utahDEM
Unfortunately that didn't fix it 😕. I still get "Failed to update feature layer: 0" even when I replaced the tuples with lists.
EarlMedina
Just to simplify things further, how about if you just remove all the extra stuff and send in this?
  "geometry": {
    "paths": [
          40.77248,
          -111.8377
          40.77254,
          -111.83776
          40.7728,
          -111.83804
          40.7728,
          -111.83804
          40.77248,
          -111.8377
I think you had some nesting going on before.
GIS_utahDEM
This is what I get:
EarlMedina
Remember it's expecting a list so it has to be adds=[temp_line]
