Optimize ItemGraph dependency mapping for large organizations via bulk fetching, type routing, and direct REST parsing
Background TheItemGraphclass and the Admin Insights dependency notebook are excellent tools for mapping item relationships in ArcGIS Online. However, for medium-to-large organizations (2,000+ items), the current implementation becomes a severe operational blocker. A full dependency scan for ~2,500 items takes approximately…
Copying attachments from one feature layer to another in AGOL Notebooks
Hello! I have two layers— Trees and RemovedTrees— in a hosted feature layer and I'm trying to create in script in AGOL Notebooks (Python 3 Standard- 14.0) that will query the Trees layer for any trees marked as removed and copy them to the RemovedTrees layer. I have it working except for the attachments, which I would also…
Use ArcGIS API for Python to configure a web map layer's Form based on popup?
My web map layers all have optimal popups configured because this is done automatically using arcpy with CIM before the layers are automatically published from ArcGIS pro to AGOL using the same arcpy script that configures the popups. In the ArcGIS Online Field Maps Designer, I can interactively create nice forms for these…
Python API Newbie needs syntax help!
I am relatively new to the Python API and need some help modifying a Notebook. Code is below. Line 42 has no impact on the target dataset and I cannot figure out why. Hopefully I've included enough of the notebook that someone can deduce my error. There's a bunch of stuff that happens before this cell, but I don't think…
Bugs and Enhancements Data Export
Is there a way to export data from the Bugs and Enhancements page via API or through an automated process?
Possible to edit features with API key authentication
I've been trying to set up a Python script that authenticates to AGOL with an API key and updates a featurelayer (delete, add). I can acccess the featurelayer but when I try to truncate it I get a 403 error: Exception: User does not have permissions to access this service. User does not have permissions to access this…
Updating attribute values for hosted feature layer using ArcPy vs ArcGIS API for Python?
Hi, I'm working within a Python Notebook in ArcPro and I'm wanting to update attribute values for a subset of my feature layer and I'm considering two approaches. I identified the features I want to update attributes value for by first using SelectLayerByAttribute and then SelectLayerByLocation. From there I feel I could…
Publish reference feature service to enterprise
Hi All, I'm trying to replicate the process normally done in Pro, using Publish Web Layer referencing registered data but instead using Python. I can create a new hosted feature service from data stored in out SDE database but I don't want to host the data I want to reference data in our SDE database, as running the…
Layer.calculate occasionally hangs
I have a python script that runs every hour or so as a windows scheduled task and does some updates to an ArcGIS Online hosted feature layer using the layer.calculate function. Every so often (once every couple of days) it hangs. The layer it hangs on only has 1600 records and the query reduces that to 26 records so it…
spatial.join silently returns 0 rows if a point has 'NaN' coordinates (arcpy engine)
Describe the bug One point with 'NaN' coordinates makes spatial.join return 0 rows with no error when arcpy is the geometry engine. full_extent also returns nan. With shapely as the engine, the same data raises an error. ESRI REST Service queries can return 'NaN' in geometries. To Reproduce Steps to reproduce the behavior:…
Thank You Python API Community - v2.4.4
With the release of ArcGIS API for Python 2.4.4, we want to extend a huge thank you to our community. Your feedback and active participation are what truly shape the evolution of this product. For those new to the ecosystem, our public GitHub repository is your go-to hub for samples, tutorials, and documentation. Your…
Unable to extract deleted features from feature service
Hello all, I am trying to create a notebook that will show me all the deleted features from a hosted feature layer and put them into a spatial data frame to review, idea being we can pull from that SDF later if needed. I have the exact same script created on our "sandbox" environment on the mirrored hosted layer, however…
Count Points in Polygons using the ArcGIS API for Python
https://youtu.be/Wtrsev5v30E Spatial analysis often involves answering a deceptively simple question: How many features are located within each area? How many properties are in each district? How many trees are in each park? How many incidents occurred in each administrative boundary? How many inspection points fall within…
Enable the FeatureLayer.calculate() method in the ArcGIS API for Python to accept Arcade expressions for calculating attribute values.
Current limitation The FeatureLayer.calculate() method currently supports calculating field values using SQL expressions or scalar values. However, there is no direct way to apply an Arcade expression through this method. This creates a gap for workflows that rely on Arcade for attribute calculation logic, particularly…
Unable to authenticate ArcGIS Online dataset for use in Arpy geoprocessing tool
I have a hosted feature service on arcgis.com that is not publicly shared and I need to read the data from a python script. The below script has been running without issue until recently. I now get a 000732 error ("Dataset does not exist or is not supported") when the MakeFeatureLayer_management tool executes. I printed…
Automating ArcGIS Notebooks
Hello, for context I am currently developing a way to have records automatically added to a "Master Results Table". I am using a feature layer in AGOL that has tasks enabled through Field Maps Designer. Within the EsriTask workflow, the field team will be required to complete a Survey123 form. There is n many Survey123…
FeatureLayer.query() giving Exception - TypeError: '>=' not supported between instances of 'int' and 'NoneType'
While querying Feature Layer getting Exception as <em><strong>"</strong></em><em>TypeError: '>=' not supported between instances of 'int' and 'NoneType' "</em> But the same outStatistics value and where clause is working fine in the REST end point in the browser, and giving the expected result. <em> </em> // Below code is…
FeatureLayer.query() not returning a feature set
Hello, I am looking to create a spatially enabled dataframe from a FeatureSet with the ArcGIS API for Python. I have always: * Created a FeatureLayer object * Used .query(where="whatever") to return a feature set, * Used the .sdf property to create the dataframe. Today the sdf property doesn't work, .query() is returning a…
clone_items() fails cloning hosted feature layer
First, a couple bullets with some basic information * ArcGIS Pro version: 3.6.3 * Source: ArcGIS Enterprise organization * Target: ArcGIS Online organization * Cloning between same source/target organizations worked previously with another Feature Layer Collection. I'm trying to clone a Feature Layer with a Survey123 point…
Update feature geometry?
I have a script that is supposed to replace the geometry of a polygon with a new polygon constructed by reading some of its fields (minX, minY, maxX, maxY). I can do this with traditional arcpy, but I'm running into issues when trying to do it with the arcgis module. Specifically, I either get no edits to the geometry if I…
What is wrong with this code?
Good afternoon, I am trying to overwrite an AGOL hosted feature class with API Python and testing it from ArcGIS Pro Notebook. I am able to load the zipped FGDB in AGOL and overwrite the hosted feature class manually. When I try to do the same thing with my program, selecting the same zipped FGDB, I get the following error…
Which cell tag to use for AGOL Notebook parameters: injected-parameters or parameters?
The docs list two different cell tags to use when setting up a Notebook to use external parameters. In one place they say to use injected-parameters but in another they say to use parameters. After some experimentation I think parameters is correct when I'm calling the Notebooks from arcgis.notebook.execute_notebook(), but…
Expose ArcGIS Online Required and Suggested Metadata Elements Scores to API for Python
My organization is attempting to create an automated process using the API for Python to check items in our organization against our customized publishing guidelines (i.e., summary, tags, categories, etc). Our process is similar to this example, but much more in-depth and linked to a live dashboard to monitor…
Error on code that was working three weeks ago: (gis.content.get(item_id)).layers[0] ("module 'arcgis.layers' has no attribute '_ogc' ")
I am calling in a layer from an item ID by using the arcgis module "layers". If I just pull in the item using gis.content.get(item_id), the item shows up fine. When I try to get to the layers though, I get the error module 'arcgis.layers' has no attribute '_ogc' . This was working for a long time, and is my go-to method…
FeatureLayerCollection.replicas.create always returns the correct tables but 0 records in the tables
Hi there. I have a python script that attempts to export a hosted feature service as a file geodatabase using the python api's featurelayercollection.replicas.create() method. I am running python 3.11.10 and arcgis api 2.3.0 The service details: - One feature layer (id: 0, geometry type: point) with attachments - One…
