Arc Py GIS
Hi, My name Kelvin I am look for the MOOC class on this subject , can some one help
Unable to extract deleted features from feature service
Hello all, I am trying to create a notebook that will show me all the deleted features from a hosted feature layer and put them into a spatial data frame to review, idea being we can pull from that SDF later if needed. I have the exact same script created on our "sandbox" environment on the mirrored hosted layer, however…
Count Points in Polygons using the ArcGIS API for Python
https://youtu.be/Wtrsev5v30E Spatial analysis often involves answering a deceptively simple question: How many features are located within each area? How many properties are in each district? How many trees are in each park? How many incidents occurred in each administrative boundary? How many inspection points fall within…
Enable the FeatureLayer.calculate() method in the ArcGIS API for Python to accept Arcade expressions for calculating attribute values.
Current limitation The FeatureLayer.calculate() method currently supports calculating field values using SQL expressions or scalar values. However, there is no direct way to apply an Arcade expression through this method. This creates a gap for workflows that rely on Arcade for attribute calculation logic, particularly…
Unable to authenticate ArcGIS Online dataset for use in Arpy geoprocessing tool
I have a hosted feature service on arcgis.com that is not publicly shared and I need to read the data from a python script. The below script has been running without issue until recently. I now get a 000732 error ("Dataset does not exist or is not supported") when the MakeFeatureLayer_management tool executes. I printed…
Automating ArcGIS Notebooks
Hello, for context I am currently developing a way to have records automatically added to a "Master Results Table". I am using a feature layer in AGOL that has tasks enabled through Field Maps Designer. Within the EsriTask workflow, the field team will be required to complete a Survey123 form. There is n many Survey123…
FeatureLayer.query() giving Exception - TypeError: '>=' not supported between instances of 'int' and 'NoneType'
While querying Feature Layer getting Exception as <em><strong>"</strong></em><em>TypeError: '>=' not supported between instances of 'int' and 'NoneType' "</em> But the same outStatistics value and where clause is working fine in the REST end point in the browser, and giving the expected result. <em> </em> // Below code is…
FeatureLayer.query() not returning a feature set
Hello, I am looking to create a spatially enabled dataframe from a FeatureSet with the ArcGIS API for Python. I have always: * Created a FeatureLayer object * Used .query(where="whatever") to return a feature set, * Used the .sdf property to create the dataframe. Today the sdf property doesn't work, .query() is returning a…
arcpy.da.TableToNumPyArray
Has anyone else noticed that when using arcpy.da.TableToNumPyArray on a joined tabled that has a definition query the resultant imported table did not fully reflect the definitionQuery?
clone_items() fails cloning hosted feature layer
First, a couple bullets with some basic information * ArcGIS Pro version: 3.6.3 * Source: ArcGIS Enterprise organization * Target: ArcGIS Online organization * Cloning between same source/target organizations worked previously with another Feature Layer Collection. I'm trying to clone a Feature Layer with a Survey123 point…
Update feature geometry?
I have a script that is supposed to replace the geometry of a polygon with a new polygon constructed by reading some of its fields (minX, minY, maxX, maxY). I can do this with traditional arcpy, but I'm running into issues when trying to do it with the arcgis module. Specifically, I either get no edits to the geometry if I…
What is wrong with this code?
Good afternoon, I am trying to overwrite an AGOL hosted feature class with API Python and testing it from ArcGIS Pro Notebook. I am able to load the zipped FGDB in AGOL and overwrite the hosted feature class manually. When I try to do the same thing with my program, selecting the same zipped FGDB, I get the following error…
Which cell tag to use for AGOL Notebook parameters: injected-parameters or parameters?
The docs list two different cell tags to use when setting up a Notebook to use external parameters. In one place they say to use injected-parameters but in another they say to use parameters. After some experimentation I think parameters is correct when I'm calling the Notebooks from arcgis.notebook.execute_notebook(), but…
Expose ArcGIS Online Required and Suggested Metadata Elements Scores to API for Python
My organization is attempting to create an automated process using the API for Python to check items in our organization against our customized publishing guidelines (i.e., summary, tags, categories, etc). Our process is similar to this example, but much more in-depth and linked to a live dashboard to monitor…
Error on code that was working three weeks ago: (gis.content.get(item_id)).layers[0] ("module 'arcgis.layers' has no attribute '_ogc' ")
I am calling in a layer from an item ID by using the arcgis module "layers". If I just pull in the item using gis.content.get(item_id), the item shows up fine. When I try to get to the layers though, I get the error module 'arcgis.layers' has no attribute '_ogc' . This was working for a long time, and is my go-to method…
Consuming ArcGISPro -py3 scripts for Spatial Projections
Hello All. I have a web application hosted on a windows server with ArcGIS windows 12 enterprise( server) that conumes the arcpy scripts for SpatialReference and project to WGSSpatialReference. Will every user on the web application initiating projection of a set of coordinates( happens in the background without generating…
FeatureLayerCollection.replicas.create always returns the correct tables but 0 records in the tables
Hi there. I have a python script that attempts to export a hosted feature service as a file geodatabase using the python api's featurelayercollection.replicas.create() method. I am running python 3.11.10 and arcgis api 2.3.0 The service details: - One feature layer (id: 0, geometry type: point) with attachments - One…
Issue with the Tutorial: "Classify land cover to measure shrinking lakes"
Classify land cover to measure shrinking lakes | ArcGIS API for Python | Esri Developer The code extracting the sentinel fata in this tutorial is not working for me. sentinel2016 = gis.content.get("a264d1eaa8bd4ff2a0a1e27b59daa7d3") sentinel2017 = gis.content.get("ea192d03d1324c62a2cb91e26e3a0ece") These Item IDs do not…
Issue with the deep learning tutorial: "Detecting Swimming Pools using Satellite Imagery and Deep Learning"
Detecting Swimming Pools using Satellite Imagery and Deep Learning | ArcGIS API for Python | Esri Developer There is an issue in this tutorial with the following snippet of code: ds = analytics.get_datastores(gis=gis) ds.search() where the .get_datastores() function returns a Nonetype, so ds.search() is not a valid call.…
Issue converting H3 cell boundary WKT to geometry with GeoAccessor.set_geometry()
H3 polygons work at resolution 8 but become empty at resolution 9+ Environment * ArcGIS Pro 3.6 * ArcGIS API for Python 2.4.2 * DuckDB 1.5.4 * DuckDB Spatial Extension * DuckDB H3 Extension * Python Notebook in ArcGIS Pro Description I found what appears to be a bug in GeoAccessor.set_geometry() when converting H3 cell…
Can view and assign licenses via the website, but not via the API
Hello, I'm working on a script to report add-on license assignments across multiple portals (both AGO and Enterprise) and am having issues with add-on extensions for ArcGIS Pro (e.g. Spatial Analyst). I'm also trying to avoid using a full admin account if possible, instead using a custom role. The issue is that I can…
ItemGraph Nodes of NoneType Items: How do I identify these programmatically?
I have successfully created an ItemGraph of my AGOL Organization. It is updated nightly. (Thanks to this notebook, and community feedback.) I have been trying to Navigate the resultant ItemGraph with varying degrees of success. I also have a List of AGOL Item IDs from another tool, that I was trying to use with the…
Issue with pydantic
Hi everyone, I'm migrating from ArcGIS Pro 3.1 to 3.4 and updating my code from `arcgis.mapping.WebMap` to `arcgis.map.Map` accordingly. **Environment:** - ArcGIS Pro 3.4 - arcgis 2.4.0 - arcgis-mapping 4.30.0 - Python 3.11 (conda env) - Windows 10 **The issue:** When instantiating `Map(item=webmap_item)`, I get the…
What are the ways to migrate built-In users from ArcGIS Enterprise portal 10.9.1 to 11.5?
We are planning to migrate from ArcGIS Enterprise 10.9.1 to 11.5. So What are the ways to migrate built-In users from ArcGIS Enterprise portal 10.9.1 to 11.5? Can we do it using: 1. Python Script? if yes what are dependencies to create a script? 2. Can we export built-in users from 10.9.1 and import the same in 11.5? 3.…
create_view is changing service definition on parent item
I am trying to create a hosted feature layer view that contains 2 out of 3 layers in a service. When I run create_view, my view is created correctly with 2 layers, but for some reason it is effecting the source item as well. When I go to the source item page, I only see two layers listed, however, all 3 layers are still…
