ArcGIS API for Python Blog
249
942K
40
NOTE: ArcGIS API for Python ideas require a label. See the descriptions to choose the label that best aligns with your idea submission.
| Open | Currently, if you read the configuration JSON for a web map (specifically looking at each layer within it's operation... by MikeLachance1 Regular Contributor 3 0 | 3 | 0 | |
| Open | Greetings,GeoAccessor.to_featureclass(location, overwrite=True, has_z=None, has_m=None, sanitize_columns=True) is qui... by TylerT Frequent Contributor 1 1 | 1 | 1 | |
| Open | In the API version 2.3.X and lower there was a lovely WebMap object method called get_layer() that allowed you to ret... by Clubdebambos 9 8 | 9 | 8 | |
| Open | At the moment there is no property in the RecycleItem properties property that states the date/time the item was dele... by Clubdebambos 2 0 | 2 | 0 | |
| Open | You can manually group and ungroup layers in a webmap. This functionality is required with the ArcGIS API for Python.... by Clubdebambos 3 1 | 3 | 1 | |
| Open | Currently, when using query_domain() on a hosted feature layer you are returned and empty list (which is an improveme... by Clubdebambos 1 0 | 1 | 0 | |
| Open | When using the clone_items() to clone a feature service from 1 agol account to another, ensure that Editor tracking a... by alex_mapintel Regular Contributor 3 1 | 3 | 1 | |
| Open | And what about adding this wonderful lib in notebook server on Agol?https://www.yworks.com/products/yfiles-graphs-for... by DISIG Frequent Contributor 0 1 | 0 | 1 | |
| Open | Reading the arcgis.apps.dashboard module documentation, it says "Deprecated as ArcGIS Dashboards Classic is retiring... by SimonSchütte_ct 43 15 | 43 | 15 | |
| Open | The ability to "Bulk Publish" items from a datastore is one of the more exciting developments to come out of ArcGIS P... by feralcatcolonist Occasional Contributor 2 1 | 2 | 1 | |
| Open | Currently the `search` and `advanced_search` functions do not utilize the filter parameter of the search endpoint.Thi... by engine-Listen-ivory-016 Emerging Contributor 2 0 | 2 | 0 | |
| Open | Currently GeoAccessor to_featureclass only supports overwrite table (feature class) handling. Having additional addi... by TylerT Frequent Contributor 1 0 | 1 | 0 | |
| Open | Using the "import data" function (and I believe others as well) there is a command argument to "sanitize columns" whi... by DannyGant Emerging Contributor 1 0 | 1 | 0 | |
| Implemented | We have notebooks in AGOL that we would like to trigger remotely using the API for Python. It appears to be a possibi... by ConradSchaefer__DOIT_ Regular Contributor 2 14 | 2 | 14 |
Idea Submission Guidelines
