Error prepare data
7409
22
12-01-2019 11:13 PM
Big_DataManado
I'm trying to prepare training data with this detail :
ArcGIS Pro 2.4.2
inRaster = "E:\Work\ArcDL\Base\MANADO_FIX.tif" (raster 8bit unsigned, thematic, with nodata=0)
out_folder = "E:\Work\ArcDL\gtg6"
in_training = "E:\Work\ArcDL\Experiment_BuildFoot_2\MyProject\Shape\House.shp" (shp that has Classvalue, Classname, RED, GREEN, BLUE field)
image_chip_format = "TIFF"
tile_size_x = "256"
tile_size_y = "256"
stride_x="128"
stride_y="128"
output_nofeature_tiles="ONLY_TILES_WITH_FEATURES"
metadata_format="Labeled_Tiles"
start_index = 0
classvalue_field = "Classvalue"
buffer_radius = 1
in_mask_polygons = "E:\Work\ArcDL\Experiment_BuildFoot_2\MyProject\Shape\Mask.shp"
rotation_angle = 0
I run my prepare data syntax just like this :
data = prepare_data('gtg6')
But I always ended up in this kind of error for labeled_tiles metadata format, there's no further explanation and I cant use the data for training since data.show_batch() will result in OSError: -2
Any solution?
Thanks in advance.
Big_DataManado
Thank you, I've been struggling for weeks in these prepare data thing... I don't have problem with pascal VOC or Classified Tiles metadata format from before.
by Anonymous User
Not applicable
Can you try install pillow again
pip uninstall pillow
and then install it again using
pip install pillow
Big_DataManado
AFAIK it's installed by using "conda install -c pytorch -c fastai fastai=1.0.39 pytorch=1.0.0 torchvision" but to be sured I created new environment again and installed required moduls using above command as sugested and test prepare_data() command again and stil it resulted in error.
Here's my environment clone from default environment of ArcGIS pro before running above command :
arcgis==1.6.1
asn1crypto==0.24.0
atomicwrites==1.3.0
attrs==19.1.0
backcall==0.1.0
bleach==3.1.0
certifi==2019.3.9
cffi==1.12.2
cftime==1.0.0b1
chardet==3.0.4
colorama==0.4.1
cryptography==2.6.1
cycler==0.10.0
decorator==4.4.0
defusedxml==0.5.0
despatch==0.1.0
entrypoints==0.3
et-xmlfile==1.0.1
fastcache==1.0.2
future==0.17.1
h5py==2.9.0
html5lib==1.0.1
idna==2.8
ipykernel==5.1.0
ipython==7.4.0
ipython-genutils==0.2.0
ipywidgets==7.4.2
jdcal==1.4
jedi==0.13.3
Jinja2==2.10.1
jsonschema==3.0.1
jupyter-client==5.2.4
jupyter-console==6.0.0
jupyter-core==4.4.0
jupyterlab==0.35.4
jupyterlab-server==0.2.0
keyring==19.0.1
kiwisolver==1.0.1
MarkupSafe==1.1.1
matplotlib==3.0.3
mistune==0.8.4
mkl-fft==1.0.10
mkl-random==1.0.2
more-itertools==6.0.0
mpmath==1.1.0
nbconvert==5.4.1
nbformat==4.4.0
netCDF4==1.5.0.1
nose==1.3.7
notebook==5.7.8
numexpr==2.6.9
numpy==1.16.2
openpyxl==2.6.1
pandas==0.24.2
pandocfilters==1.4.2
parso==0.3.4
pickleshare==0.7.5
pluggy==0.9.0
prometheus-client==0.6.0
prompt-toolkit==2.0.9
py==1.8.0
pycparser==2.19
Pygments==2.3.1
pyOpenSSL==19.0.0
pyparsing==2.4.0
pyrsistent==0.14.11
pyshp==1.2.12
PySocks==1.6.8
pytest==4.4.0
python-dateutil==2.8.0
pytz==2018.9
pywin32-ctypes==0.2.0
pywinpty==0.5
pyzmq==18.0.0
requests==2.21.0
scipy==1.2.1
Send2Trash==1.5.0
simplegeneric==0.8.1
six==1.12.0
sympy==1.3
terminado==0.8.1
testpath==0.4.2
tornado==6.0.2
traitlets==4.3.2
urllib3==1.24.1
wcwidth==0.1.7
webencodings==0.5.1
widgetsnbextension==3.4.2
win-inet-pton==1.1.0
wincertstore==0.2
winkerberos==0.7.0
x86cpu==0.4
xlrd==1.2.0
xlwt==1.3.0
and here's my environment after running above command :
arcgis==1.6.2
asn1crypto==1.2.0
atomicwrites==1.3.0
attrs==19.3.0
backcall==0.1.0
bleach==3.1.0
blis==0.2.4
Bottleneck==1.3.1
certifi==2019.11.28
cffi==1.13.2
cftime==1.0.0b1
chardet==3.0.4
colorama==0.4.1
cryptography==2.8
cycler==0.10.0
cymem==2.0.2
dataclasses==0.6
decorator==4.4.1
defusedxml==0.6.0
despatch==0.1.0
entrypoints==0.3
et-xmlfile==1.0.1
fastai==1.0.39
fastcache==1.1.0
fastprogress==0.1.22
future==0.18.2
h5py==2.9.0
html5lib==1.0.1
idna==2.8
importlib-metadata==1.1.0
ipykernel==5.1.3
ipython==7.9.0
ipywidgets==7.5.1
jdcal==1.4.1
jedi==0.15.1
Jinja2==2.10.3
json5==0.8.5
jsonschema==3.2.0
jupyter-client==5.3.4
jupyter-console==5.2.0
jupyter-core==4.6.1
jupyterlab==1.2.3
jupyterlab-server==1.0.6
keyring==19.2.0
kiwisolver==1.1.0
MarkupSafe==1.1.1
matplotlib==3.0.3
mistune==0.8.4
mkl-fft==1.0.12
mkl-random==1.0.2
more-itertools==7.2.0
mpmath==1.1.0
murmurhash==1.0.2
nb-conda==2.2.1
nb-conda-kernels==2.2.2
nbconvert==5.6.1
nbformat==4.4.0
netCDF4==1.5.0.1
nose==1.3.7
notebook==6.0.2
numexpr==2.6.9
numpy==1.16.2
olefile==0.46
openpyxl==3.0.2
packaging==19.2
pandas==0.25.3
parso==0.5.1
pickleshare==0.7.5
Pillow==6.2.1
plac==0.9.6
pluggy==0.13.1
preshed==2.0.1
prompt-toolkit==3.0.2
py==1.8.0
pycparser==2.19
Pygments==2.5.2
pyOpenSSL==19.1.0
pyparsing==2.4.5
pyrsistent==0.15.6
pyshp==1.2.12
PySocks==1.7.1
pytest==5.3.1
python-dateutil==2.8.1
pytz==2019.3
pywin32==223
pywinpty==0.5.5
PyYAML==3.12
pyzmq==18.1.0
requests==2.22.0
scipy==1.2.1
Send2Trash==1.5.0
six==1.13.0
spacy==2.1.8
srsly==0.1.0
sympy==1.4
terminado==0.8.3
testpath==0.4.4
thinc==7.0.8
torch==1.0.0
torchvision==0.2.2
tornado==6.0.3
tqdm==4.40.0
traitlets==4.3.3
typing==3.6.4
urllib3==1.24.2
wasabi==0.2.2
wcwidth==0.1.7
webencodings==0.5.1
widgetsnbextension==3.5.1
wincertstore==0.2
winkerberos==0.7.0
x86cpu==0.4
xlrd==1.2.0
xlwt==1.3.0
zipp==0.6.0
it seems the pillow were installed by command above using conda install, and this is what changed :
anything wrong with my setup or I missed something?
Thanks in advance.
by Anonymous User
Not applicable
To verify your pillow installation try to load an exported image chip directly using the following code
from PIL import Image
Image.open(image_path)
it should give a similar output as below
Big_DataManado
Now it seems to make sense, it resulted in an error :
so what should I do ? in another side I need this conda install -c pytorch -c fastai fastai=1.0.39 pytorch=1.0.0 torchvision command to prepare_data()
Big_DataManado
One more thing, it can read normal image png, but it won't work from image created from export training data
by Anonymous User
Not applicable
Can you uninstall pillow
pip install pillow
If still you are not able to read the image please attach the image here.
Big_DataManado
Okay, now I can read the Image from export training data but it leaves some error and I'm afraid it will cause something wrong later :
image successfully read :
should I run :
conda install -c fastai nvidia-ml-py3
since I'm using GPU for this
by Anonymous User
Not applicable
Big Data Manado‌ we can ignore this warning for now.
Big_DataManado
Ok, Thank you for your help.
