Cloning Content from AGOL to Enterprise
2782
02-23-2022 12:26 PM
MatthewObuck
Sorry if this is the wrong place to post this. Currently, I'm trying to copy data from ArcGIS Online to Enterprise. Some of the content will include: Webmaps, Survey123 Forms, Tile Packages, and Feature Layers. I've looked into using the API for Python to get this to work, notably the clone_items tool: (https://developers.arcgis.com/python/guide/cloning-content/)
Setting the "copy_data" value to false does clone the content. However, requires the old AGOL login information to be entered to access the items. Setting this value to true gives me the error:
Access to admin resources are not allowed.\n(Error Code: 403)
Both the source and target accounts are administrative accounts. Any help or advice would be awesome!
Thanks!
ABishop
Hello Matthew,
Have you tried the AGOL assistant?  https://ago-assistant.esri.com/
Amanda Bishop, GISP
MatthewObuck
Hello Amanda,
Yes I have, it works for some items. However, is unable to copy Survey123 Forms. I have also seen it delete attribute data when copying over.
David
by Esri Contributor
Try these these ArcGIS Notebooks from Esri Professional Services. They are for templatizing and cloning content between orgs and enterprises.
