ArcGIS API for Python Blog
249
941.2K
39
NOTE: ArcGIS API for Python ideas require a label. See the descriptions to choose the label that best aligns with your idea submission.
| Open | My organization is attempting to create an automated process using the API for Python to check items in our organizat... by ColinBergmann_ct Occasional Contributor 5 0 | 5 | 0 | |
| Open | See question posted here: Does the python Suvey 123 api support creating a n... - Esri Community by ashcom Emerging Contributor 1 0 | 1 | 0 | |
| Open | Since the Februari 2026 update of ArcGIS Online, using gis.admin is no longer possible using an API key in ArcGIS Onl... by TjibbeWubbels Regular Contributor 3 0 | 3 | 0 | |
| Open | If you provide the group.remove_users() Fuction a list with 25 or more users, the function will fail with the followi... by MarcelBeckmann Frequent Contributor 2 0 | 2 | 0 | |
| Open | It would be useful for geoprocessing tools executed in ArcGIS Enterprise—especially when triggered from Experience Bu... by SimonP Occasional Contributor 1 0 | 1 | 0 | |
| Open | When cloning webmaps from one portal to another, it is possible to provide a lookup dictionary with {source_item_id :... by MarcelBeckmann Frequent Contributor 2 0 | 2 | 0 | |
| Open | Attempting to clone content between ArcGIS Enterprise deployments when authenticated using oauth 2.0 (using the clien... by TraeTimmerman Occasional Contributor 2 0 | 2 | 0 | |
| Closed | Credentials for user accounts are stored in Azure Keyvault and are accessed during runtime using. There is need to se... by VidyaSagarGurung Emerging Contributor 1 1 | 1 | 1 | |
| Open | Adding an image to a StoryMap Briefing using the GUI automatically fits the image to the size of the Block. After add... by ATFerguson Regular Contributor 0 0 | 0 | 0 | |
| Open | Hi,Please adjust the item_id parameter of the arcgis.gis.server.Server.publish_sd function to support a dictionary of... by PatriceLabbé Frequent Contributor 2 0 | 2 | 0 | |
| Open | Currently, if you read the configuration JSON for a web map (specifically looking at each layer within it's operation... by MikeLachance1 Regular Contributor 3 0 | 3 | 0 | |
| Open | Please update the API to enable adding all Layers and Tables at once.As of the ArcGIS API for Python version 2.4.0 an... by Clubdebambos 0 0 | 0 | 0 | |
| Open | The extract_changes function of a FeatureLayerCollection in the Esri Python API (arcgis python library) does not have... by GFlonk Occasional Contributor 1 1 | 1 | 1 | |
| Open | When exporting data to a particular format, provide methods that enable users to check what potential limitations may... by PeterKnoop 1 2 | 1 | 2 | |
| Open | Greetings,GeoAccessor.to_featureclass(location, overwrite=True, has_z=None, has_m=None, sanitize_columns=True) is qui... by TylerT Frequent Contributor 1 1 | 1 | 1 |
Idea Submission Guidelines
