I need to center a graphic element on the map
1008
07-07-2022 08:49 AM
stiven
I want to position the search engine in the middle of the map, I have only found the positions of : "bottom-leading"|"bottom-left"|"bottom-right"|"bottom-trailing"|"top-leading"|"top-left"|"top-right"|"top-trailing"|"manual"
i want this:
KellyHutchins
Esri Frequent Contributor
You can use the manual option then position the search component with CSS. This example isn't perfect but it'll show you the general steps
https://codepen.io/kellyhutchins/pen/poLyJwK?editors=100
Here's the css that is used in the sample:
      .esri-ui-manual-container>.esri-component.esri-search {
        position: absolute;
        left: calc(50vw - 120px);
        top: 20px;
KellyHutchins
        position: absolute;
        top: 20px;
stiven
Thank you very much, that worked
CherieBryant
This was very helpful and got me on the right track. Thank you!
If you can make the width of the element to be centered a percentage, then the remainder can be split in half for the left margin. I'm using a custom container here for a slider bar.
#sliderContainer {
  width: 50%;
.esri-ui-manual-container > div#sliderContainer.box.esri-component {
  left: 25%;
