ArcGIS Maps SDK for JavaScript, get the number of items returned after applying a filter (client-side)
1464
03-10-2023 01:33 AM
Humberto
I am newbie to ArcGIS Maps  SDK for Javascript.
I have done a filter by attributes (from user selection) on client-side. It works right, but I would like to show a message if the filter doesn't return any item. Is it possible with any method with my approach or should I change it?
Here is my code : https://codepen.io/gisdevelopment/pen/OJozLzw
UndralBatsukh
Hi there,
You will have to query the features on the layer view once you change the layer view's feature filter. You can do it as shown below:
// Get a query object from the filter's current configuration
const queryParams = earthquakesLayerView.filter.createQuery();
earthquakesLayerView.queryFeatures(queryParams)
.then(function(results){
   console.log("results", results.features);
UndralBatsukh
Hi there,
Humberto
Thank you very much
