Is it possible to override default tooltips?
14837
28
04-02-2014 09:35 AM
RobertKirkwood
I would like to be able to override the default tooltips for the Homebutton, Simple Slider, and the Locate buttons.  I have other tooltips in the map and i want the tooltips to all look the same.
KellyHutchins
Esri Notable Contributor
Hi Robert,
Here's a link to a help topic that explains how to override the default strings in the JSAPI.
https://developers.arcgis.com/javascript/jshelp/inside_bundle.html
RobertKirkwood
Hi Robert,
Thanks. I have looked and can't seem to find anything that talks about the default tootip being overwritten specifically. I have tried the code below for the Homebutton and the Locate button, but it doesn't seem to work. I have even put in the variable map.
require(["dijit/Tooltip", "dojo/domReady!"], function(Tooltip){
 new Tooltip({
        connectId: ["HomeButton"],
        label: "Home",
  orient: ['before'],
I have also tried this in my .css file:
.HomeButton .tooltip {
    font-family: Arial !important;
    font-size: 11px !important;
    font-weight: bold !important;
    background-color: white !important;
I am not sure what i am missing here? Thanks for the help!
KellyHutchins
The link I posted shows how to change the default text for the tooltip. Are you trying to change the text or do you want to modify the appearance of the tooltip?
RobertKirkwood
I am trying to change the default style. I have a white box with a border around the rest of the tooltips in the map. here are the examples:
[ATTACH=CONFIG]32743[/ATTACH]
[ATTACH=CONFIG]32744[/ATTACH]
RobertKirkwood
I would also like to change the position of the tooltip...
KellyHutchins
Ok so the current tooltip for the Home Button is generated using the HTML title attribute Basically when you add the title attribute to an HTML tag the browser will display a tooltip. The style is browser dependent and I don't know of a way to modify the style.
One approach might be to remove the title attribute then add a new one - maybe data-title and then use the mechanism you are using to generate the other tooltips to generate that one.  Here's a sample that show hiding the existing tooltip and creating a new one using css.
<!DOCTYPE HTML>
<html>
<head>
  <meta charset="utf-8">
  <title>Home Extent</title>
  <link rel="stylesheet" type="text/css" href="http://js.arcgis.com/3.8/js/esri/css/esri.css">
  <style>
    html, body, #map {
      padding:0;
      margin:0;
      height:100%;
    #HomeButton {
      position: absolute;
      top: 95px;
      left: 20px;
      z-index: 50;
[data-title]:hover:after {
  content: attr(data-title);
  padding: 4px 8px;
  color: #333;
  position: absolute;
  left: 0;
  top: 100%;
  white-space: nowrap;
  z-index: 20px;
  -moz-border-radius: 5px;
  -webkit-border-radius: 5px;
  border-radius: 5px;
  -moz-box-shadow: 0px 0px 4px #222;
  -webkit-box-shadow: 0px 0px 4px #222;
  background-image: -moz-linear-gradient(top, #eeeeee, #cccccc);
  background-image: -webkit-gradient(linear,left top,left bottom,color-stop(0, #eeeeee),color-stop(1, #cccccc));
  background-image: -webkit-linear-gradient(top, #eeeeee, #cccccc);
  background-image: -ms-linear-gradient(top, #eeeeee, #cccccc);
  background-image: -o-linear-gradient(top, #eeeeee, #cccccc);
  </style>
  <script src="//js.arcgis.com/3.8/"></script>
  <script>
    require([
      "esri/map",
      "esri/dijit/HomeButton",
      "dojo/i18n!esri/nls/jsapi",
      "dojo/query",
      "dojo/dom-attr",
      "dojo/domReady!"
    ], function(
      Map, HomeButton,esriBundle, query, domAttr
      var map = new Map("map", {
        center: [-56.049, 38.485],
        zoom: 3,
        basemap: "streets"
      var home = new HomeButton({
        map: map
      }, "HomeButton");
      home.startup();
      query(".home").forEach(function(node){
        //remove the title attribute
        //Get the title attribute
        if(domAttr.get(node, "title") === esriBundle.widgets.homeButton.home.title){
          //replace the title attribute with data-title
          domAttr.remove(node, "title");
          domAttr.set(node, "data-title", esriBundle.widgets.homeButton.home.title )
  </script>
</head>
<body>
  <div id="map" class="map">
    <div id="HomeButton"></div>
  </div>
</body>
</html>
RobertKirkwood
Excellent! Wow, nice work and thanks so much!
[ATTACH=CONFIG]32747[/ATTACH]
So, now i can do the same thing for the Locate button? I will test that out and see if it works for that too...
RobertKirkwood
one more question: what is the format for the Locate button widget? i.e. for the Homebutton its  "esriBundle.widgets.homeButton.home.title"
Thanks again!
KenBuja
MVP Esteemed Contributor
If you're using an IDE that has debugging, you can pause it and examine esriBundle. That's how I was able to find the right property in this thread.
