Is it possible to override default tooltips?
21468
28
04-02-2014 09:35 AM
RobertKirkwood
I would like to be able to override the default tooltips for the Homebutton, Simple Slider, and the Locate buttons.  I have other tooltips in the map and i want the tooltips to all look the same.
RobertKirkwood
Are you sure you're looking at the right variable? I'm seeing these options for the overview map widget
[ATTACH=CONFIG]32878[/ATTACH]
Thanks. that gets me close. However, when i put this in my code "esriBundle.widgets.overviewMap.NLS_show.title = "SHOW"" or "   esriBundle.widgets.overviewMap.NLS_hide.title = "HIDE""
it doesn't overwrite the "Show Map Overview" or "Hide Overview Map" text.
This worked for the Home and Locate buttons.
Thanks again for your help!
RobertKirkwood
Are you sure you're looking at the right variable? I'm seeing these options for the overviewmap widget
Sorry! never mind i was using the left position so the tooltip was off the screen!
RobertKirkwood
Ken,
I did try the elements associated with the overviewmap as you has shown me. however, i cannot get the text to be overwritten. i can get the tooltip to pop out to the side, but it has the default "Show Map Overview" text and still shows teh default tooltip after a few seconds. I have tried many combinations and can not get it to work. here is what i was trying to work with:
var locateText = esriBundle.widgets.overviewMap.NLS_show.title;
var overviewshowText =   esriBundle.widgets.overviewMap.NLS_show.title;
      overviewMap.on("load", function(){
        query('div[title ="' +  overviewshowText + '"]').forEach(function(node){
            domAttr.remove(node, "title");
            domAttr.set(node, "show-title", overviewshowText);
any help would be greatly appreciated.  As you can tell i am new to all of this!
KenBuja
MVP Esteemed Contributor
This should work
<!DOCTYPE html>
<html>
  <head>
    <!--The viewport meta tag is used to improve the presentation and behavior of the samples
      on iOS devices-->
    <title>Overview Map</title>
    <link rel="stylesheet" href="http://js.arcgis.com/3.9/js/dojo/dijit/themes/claro/claro.css">
    <link rel="stylesheet" href="http://js.arcgis.com/3.9/js/esri/css/esri.css">
    <style>
      html, body { height: 100%; width: 100%; margin: 0; padding: 0; }
    </style>
    <script src="http://js.arcgis.com/3.9/"></script>
    <script>
      var map;
      require([
        "esri/map", "esri/dijit/OverviewMap",
        "dojo/parser",
        "dojo/i18n!esri/nls/jsapi",
        "dijit/layout/BorderContainer", "dijit/layout/ContentPane", "dojo/domReady!"
      ], function (
        Map, OverviewMap,
        parser, esriBundle
        parser.parse();
        map = new Map("map", {
          basemap: "topo",
          center: [-122.445, 37.752],
          zoom: 14
        esriBundle.widgets.overviewMap.NLS_show = "Testing";
        var overviewMapDijit = new OverviewMap({
          map: map,
          visible: true
        overviewMapDijit.startup();
    </script>
  </head>
  <body class="claro">
    <div data-dojo-type="dijit/layout/BorderContainer"
         data-dojo-props="design:'headline', gutters:false"
         style="width: 100%; height: 100%; margin:0;">
      <div id="map"
           data-dojo-type="dijit/layout/ContentPane"
           data-dojo-props="region:'center'"
           style="padding:0">
      </div>
    </div>
  </body>
</html>
RobertKirkwood
This should work
Ken,
Thanks! That does overwrite the default text. However i am now having trouble turning off the default tooltip.
[ATTACH=CONFIG]32960[/ATTACH]
Thanks again for all your help.
KenBuja
Did you try what Kelly suggested in an earlier post?
RobertKirkwood
Ken,
I have tried various versions of it. here is an example:
var showText =  esriBundle.widgets.overviewMap.NLS_show;
      overviewMapDijit.on("load", function(){
        query('div[title ="' +  showText + '"]').forEach(function(node){
            domAttr.set(node, "data-title", showText);
CSS..
[data-title]:hover:after {
    content: attr(data-title);
    text-align: center;
    font-family: Arial;
    font-size: 11px;
    font-weight: bold;
    background-color: white;
    border: 1px solid #000000;
    border-radius: 1px;
    padding: 4px 8px;
    left: 40px;
    width: 40px;
    z-index: 20px;
    position: absolute;
but to no avail...
KenBuja
Can you show an example in Fiddle or JSBin?
RobertKirkwood
Ken,
Here is a sample:
http://jsfiddle.net/Mr_Kirkwood/x4tgd/
I guess another question would be - how do i get tooltips to show up on the zoom in and zoom out buttons?
Also, the overview map is in the bottom left...
