Is it possible to override default tooltips?
21468
28
04-02-2014 09:35 AM
RobertKirkwood
I would like to be able to override the default tooltips for the Homebutton, Simple Slider, and the Locate buttons.  I have other tooltips in the map and i want the tooltips to all look the same.
RobertKirkwood
If you're using an IDE that has debugging, you can pause it and examine esriBundle. That's how I was able to find the right property in this thread.
Thanks for the information. I cant seem to get the right syntax for it...
I tried esriBundle.widgets.locateButton.title = "New" as a test.
when I  run the require(["dojo/i18n!esri/nls/jsapi"], function(b) { console.log(b); });
in the console i see the title new, but the button still has Find my location as the tooltip...
when i copy out the html from the source it looks like this:
<div class="LocateButton" role="presentation" id="LocateButton" widgetid="LocateButton" style="display: block;">
    <div class="locateContainer">
            <div data-dojo-attach-point="_locateNode" role="button" class="zoomLocateButton" title="Find my location"><span>My Location</span></div>
    </div>
</div>
here is a screenshot:
[ATTACH=CONFIG]32751[/ATTACH]
any suggestions? thanks again!
RobertKirkwood
I found it for the locateButton:
esriBundle.widgets.locateButton.locate.title
Thanks again for you help!
RobertKirkwood
the Locatebutton is a bit different from the HomeButton. here is the code that worked:
geoLocate = new LocateButton({
        map: map,
    }, "LocateButton");
    geoLocate.startup();
 query(".zoomLocateButton").forEach(function(node){
        //remove the title attribute
        //Get the title attribute
        if(domAttr.get(node, "title") === esriBundle.widgets.locateButton.locate.title){
          //replace the title attribute with data-title
          domAttr.remove(node, "title");
          domAttr.set(node, "title", esriBundle.widgets.locateButton.locate.title )
and the css:
[title]:hover:after {
    content: attr(title);
    text-align: center;
    font-family: Arial;
    font-size: 12px;
    font-weight: bold;
    background-color: white;
    border: 1px solid #000000;
    border-radius: 1px;
    padding: 4px 8px;
    left: 40px;
    width: 125px;
    z-index: 20px;
    position: absolute;
However, the regular tooltip shows up as well...
[ATTACH=CONFIG]32755[/ATTACH]
KellyHutchins
Esri Notable Contributor
It looks like the issue is that the title attribute isn't getting removed from the locate button - perhaps due to a timing issue. It seems to work if I wait and remove the text after the locate button has loaded. Here's some sample code that shows this:
      var homeText =  esriBundle.widgets.homeButton.home.title;
      var locateText =  esriBundle.widgets.locateButton.locate.title;
      geoLocate.on("load", function(){
        query('div[title ="' +  locateText + '"]').forEach(function(node){
            domAttr.set(node, "data-title", locateText);
      home.on("load", function(){
        //Remove default tooltip for home button
        query('div[title ="' +  homeText + '"]').forEach(function(node){
            domAttr.set(node, "data-title", homeText);
RobertKirkwood
Thanks. How do i use this code then? Here is my full java script:
 var map;
var bMap = "topo";
function changeBasemap(bm) {
        bMap=bm;
        map.setBasemap(bMap);
require(["esri/map", "esri/toolbars/navigation",
"dojo/on",
"dojo/parser",
"dijit/registry",
"dijit/Toolbar",
"dijit/form/Button",
"esri/dijit/OverviewMap",
"esri/dijit/Scalebar",
"esri/dijit/LocateButton",
"esri/dijit/HomeButton",
"dojo/i18n!esri/nls/jsapi",
"dojo/query",
"dojo/dom-attr",
"dojo/domReady!"],
function(Map, Navigation, on, parser, registry, Toolbar, Button, OverviewMap, Scalebar, LocateButton, HomeButton, esriBundle,  query, domAttr ){
      esriBundle.widgets.homeButton.home.title = "HOME"
   esriBundle.widgets.locateButton.locate.title = "FIND MY LOCATION"
    parser.parse();
    var navToolbar;
    map = new Map("map", {
        basemap: "topo",
        center: [-107.646372, 43.433484],
        zoom: 7,
        slider: "small"
    on(map, "load", addDataLayersInit);
    on(map, "layers-add-result", initTOC);
    //on(map, "layers-add-result", initTOC_Obs);
    var scalebar = new Scalebar({
        map: map,
        // "dual" displays both miles and kilmometers
        // "english" is the default, which displays miles
        // use "metric" for kilometers
        scalebarUnit: "dual",
            attachTo:"bottom-right"
        map: map,
    }, "LocateButton");
      var home = new HomeButton({
        map: map
      }, "HomeButton");
      home.startup();
        query(".home").forEach(function(node){
        if(domAttr.get(node, "title") === esriBundle.widgets.homeButton.home.title){
          domAttr.set(node, "data-title", esriBundle.widgets.homeButton.home.title )
    navToolbar = new Navigation(map);
    on(navToolbar, "onExtentHistoryChange", extentHistoryChangeHandler);
    registry.byId("zoomprev").on("click", function(){
        navToolbar.zoomToPrevExtent();
    registry.byId("zoomnext").on("click", function(){
        navToolbar.zoomToNextExtent();
    function extentHistoryChangeHandler(){
        registry.byId("zoomprev").disabled = navToolbar.isFirstExtent();
        registry.byId("zoomnext").disabled = navToolbar.isLastExtent();
    var overviewMapDijit = new OverviewMap({
        map: map,
        visible: false,
            attachTo: "bottom-right",
            width: 200,
            height: 200
    overviewMapDijit.startup();
KellyHutchins
Robert,
You'll want to replace your existing code that creates the home and locate button with the code I provided.
RobertKirkwood
Robert,
Kelly,
Thank you so much for your help. That worked out perfectly!
KenBuja
MVP Esteemed Contributor
Don't forget to click the check on the appropriate post to mark this thread as answered. This will help others in searching on this topic.
RobertKirkwood
Robert,
Well, I am now having trouble with the tooltip for the overview map show/hide button. I am not sure how to get the
"esriBundle.widgets.esriOverviewMap.ovwButton.title" to work correctly. Will i need two of these since there is a show and hide button?
KenBuja
Are you sure you're looking at the right variable? I'm seeing these options for the overviewmap widget
[ATTACH=CONFIG]32878[/ATTACH]
