Add X, Y coordinates
489
10-22-2013 07:13 AM
BerryFarrington
I have a point shapefile, county coordinates. I would like to add x, y data presented as decimal degrees. When I use the Add x, y coordinates tool, I get state plane coordinates. I've transformed the shapefile to UTM projection and again added the x,y coordinates, but I am still getting state plane rather than latitude and longitude. Any suggestions?
RobertBorchert
Honored Contributor
Start a blank ArcGIS session.  Add your projected shapefile to the session.
open the attribute table for the shapefile and add a X and Y attributes.  Make them both type Double.
Right click on the X attribute and select calculate Geometry.
It should default to the coordinate system of your source.  Make sure the property is set to X coordinate of point.  From the bottom drop down menu select your units.
Calculate.
do the same for the Y coordinate
TimWitt
Jane,
Can you use the project tool, to reproject it into WGS84 (Coordinate System -> World -> WGS 1984)?
Tim
BerryFarrington
Thanks! Both solutions worked.
RobertBorchert
Honored Contributor
Calculate.
