Calculate age in field calc using python parser
3443
12-17-2012 07:48 AM
JustinNettleton
I am looking to calculate an Age field from a DOB field using the python Parser in Desktop field calculator. Does anyone know the syntax I would need to use?
AndrewChapkowski
Using the code box in field calculator, you can subtract two python datatime objects from each other.
For the code block use something like this:
def dateDiff(date):    from datetime import datetime    return int((datetime.now( ) - datetime.strptime(date,"%m/%d/%Y")).days/365.2425)
In the expression just enter in the name the following:
dateDiff( !DOB! )
Where field DOB is a date field.
AndrewChapkowski
dateDiff( !DOB! )
JustinNettleton
Thanks, works perfect.
DanielO_Donnell
This works very well, unless there is a NULL value in a record. Naturally, one doesn't always have a DOB for each record.
Any ideas?
I Add Field "Age", then Calculate Field using the above python algorythm... however, I get an error when it hits NULL values.
ERROR 000539:
Error running expression datediff ( " " ) <type 'exceptions.ValueError'>: time data ' ' does not match format '%Y%m%d'
Failed to execute (Calculate Field: AGE)
LucasDanzinger
Esri Frequent Contributor
If you are at 10.1, you can just test to see if a value is Null by checking to see if it equals None. This is highlighted in KB 40913.
You should be able to do something like:
def dateDiff(date):
   if date is None:
       pass
   else:
