simple geoproccesing giving a license error
1365
03-12-2013 07:46 AM
DAVIDMARTINEZ2
We are creating a model that contains the ???Feature to Polygon??? tool, located in ArcToolBox. The model has the following structure:
[ATTACH=CONFIG]22544[/ATTACH]
It runs fine in ArcCatalog, but when publishing and executing the geoprocessing from an ArGIS Server connection, we get a 000824 license error.
We have ArcGIS Server 10.1 Standard, and it must suport this simple geoproccesing, or that is what we suppose.
In the attached file it is fully described the process.
We appreciate any idea on how to solve this issue,
Thanks in advance,
David
by Anonymous User
Not applicable
Original User: khibma
Unfortunately the Feature to Polygon tool requires an Advanced license level in Desktop.
Tools that require an Advanced Desktop license will require an advanced license in Server as well.
Your only solution would be to increase the license level from Standard to Advanced, or re-evaluate your workflow. Maybe there is another way you could achieve the same results using another tool?
LucasDanzinger
Esri Frequent Contributor
Do you have Advanced for Desktop (I know you said standard for Server)? The Feature to Polygon requires an Advanced license.
by Anonymous User
Not applicable
DAVIDMARTINEZ2
Thanks Lucas  and Kevin for your quick responses,
We have Advanced Desktop but Standard Server licenses, and what we want to do, it's not possible to achieve with an Standard Server license.
David
