Solved! Go to Solution.
I am trying to create an application similar to the ESRI citizen request sample. I am running into a problem where I am unable to apply my edits. The error code is:
{"error":{"code":400,"message":"Unable to complete operation.","details":["Unable to apply edits"]}}
I have:
- registered the feature class as versioned
- permissions have been given. I am able to edit without problem in ArcMap; is there something else I need to do.
- checked to make sure editing is enabled on the service
Any help is greatly appreciated.
James
Thanks for the reply; however, I don't think that is my problem. I am just adding a point feature so the geometry is not very big.
This proxy is the same as I have used on other servers so I think it is also configured correctly.
Thanks for the suggestion.
It doesn't look like you are actually using a proxy for the POST. That's probably not it but just an fyi.
I wonder if your OBJECTID_1 field name is causing some confusion. It might be looking at your other field named OBJECTID which is null. That might cause an incorrect parameter error.
