Getting an error "Failed to load notebook" when opening .ipynb file in ArcGIS Pro 2.6
11452
18
07-30-2020 03:35 PM
SaraLoreno1
I have tried creating new notebooks as well as opening existing notebooks, but I get the same error "Failed to load notebook".  This occurs after tab shows "Initializing Kernel". What am I missing?  Through research, it seems as if I should just be able to run notebooks through arc pro without additional downloads. Thanks in advance.
DanPatterson
MVP Esteemed Contributor
Sara Loreno You don't need any additional downloads.
Can you give an example of a "new" notebook you are trying to create?
or does it fail immediately when you try to make a new notebook?
... sort of retired...
SaraLoreno1
Dan,
I was able to create a new notebook by selecting Insert > New Notebook.  When I try to open the created notebook from Catalog, I get the "Failed to Load Notebook error".
I also tried opening a notebook that I created in Jupyter (I am quite familiar with Jupyter Notebooks and have been using them for years) and wasn't able to open one of the existing notebooks either.
-Sara
DanPatterson
Sara... sounds like an issue.
I can open existing and new notebooks from catalog without issue (I just can graph with matplotlib yet).
Since 2.6 is so recent, I would file a case with Technical Support.
It could be your environment or just about anything.
Good luck and report back if you get a case number or resolution.
GaxtonOkobah
"Unable to load notebook" is what I'm getting from ARCGIS PRO 3
JiříKomínek
Have you resolved this problem? I have the same problem in ARCGIS PRO 3.
SuzanneBoring
Me too
TijsLips
Yes, me too. It happened when I created a clone of the python environment and started using it. When switching back to the default environment I can open the notebooks again..
IvyGuangyueCao
Same thing happened to me when using a new env.
Have you solved the issue?
TijsLips
No, I am in contact with esri service desk to find the solution.
