I have tried creating new notebooks as well as opening existing notebooks, but I get the same error "Failed to load notebook". This occurs after tab shows "Initializing Kernel". What am I missing? Through research, it seems as if I should just be able to run notebooks through arc pro without additional downloads. Thanks in advance.
Sara Loreno You don't need any additional downloads.
Can you give an example of a "new" notebook you are trying to create?
or does it fail immediately when you try to make a new notebook?
Dan,
I was able to create a new notebook by selecting Insert > New Notebook. When I try to open the created notebook from Catalog, I get the "Failed to Load Notebook error".
I also tried opening a notebook that I created in Jupyter (I am quite familiar with Jupyter Notebooks and have been using them for years) and wasn't able to open one of the existing notebooks either.
-Sara
Sara... sounds like an issue.
I can open existing and new notebooks from catalog without issue (I just can graph with matplotlib yet).
Since 2.6 is so recent, I would file a case with Technical Support.
It could be your environment or just about anything.
Good luck and report back if you get a case number or resolution.
"Unable to load notebook" is what I'm getting from ARCGIS PRO 3
Have you resolved this problem? I have the same problem in ARCGIS PRO 3.
Yes, me too. It happened when I created a clone of the python environment and started using it. When switching back to the default environment I can open the notebooks again..
Same thing happened to me when using a new env.
Have you solved the issue?
