Iterate through features and select by location
3885
11
03-05-2020 03:34 PM
NataliaGutierrez1
I have a layer with Zoning Overlays. I have a layer with parcels. I need to iterate through zoning Overlay, select the parcels falling inside, add a new field to the parcels Feature class and add some text to the selected fields, then repeat for the next zoning overlay. The loop works, insofar but it stops with a particular error that is not specific enough.
The code runs until it has to assign the values to the second field.
Please see below for more details.
Here's my code:
Import arcpy
# Set two geoprocessing environments
arcpy.env.workspace = r"D:\APRX, MXDS\Geo_Engine_Zoning_Project\Austin_Geo_Engine.gdb"
# List of fields in Merged_Ovelays FC
fields = ["OBJECTID", "zoning_ove"]
# Convert austin_parcels feature class to feature layer
arcpy.MakeFeatureLayer_management("austin_parcels", "austin_parcels_layer")
# Convert Merged_Overlays feature class to feature layer
arcpy.MakeFeatureLayer_management("Merged_Overlays", "Merged_Overlays_Layer")
# arcpy.da.SearchCursor(in_table, field_names, {where_clause}, {spatial_reference}, {explode_to_points}, {sql_clause})
with arcpy.da.SearchCursor("Merged_Overlays_Layer", fields) as cursor:
    for row in cursor:
        select = "OBJECTID = {}".format(row[0])
# SelectLayerByAttribute(in_layer_or_view, {selection_type}, {where_clause}, {invert_where_clause})
        arcpy.management.SelectLayerByAttribute("Merged_Overlays_Layer", "NEW_SELECTION", select)
# SelectLayerByLocation(in_layer, {overlap_type}, {select_features}, {search_distance}, {selection_type}, {invert_spatial_relationship})
        arcpy.management.SelectLayerByLocation("austin_parcels_layer", "HAVE_THEIR_CENTER_IN", "Merged_Overlays_Layer","","NEW_SELECTION")
# Syntax: AddField(in_table, field_name, field_type, {field_precision}, {field_scale}, {field_length}, {field_alias}, {field_is_nullable}, {field_is_required}, {field_domain})
        arcpy.management.AddField('austin_parcels_layer', "Overlay_{}".format(row[1]), "TEXT")
# CalculateField(in_table, field, expression, {expression_type}, {code_block}, {field_type})
        arcpy.management.CalculateField("austin_parcels_layer", "Overlay_{}".format(row[1]), '"Overlay_{}".format(row[1])')
I am getting the following error and I am not sure how to fix it:
File "<string>", line 24, in <module>
File "c:\program files\arcgis\pro\Resources\arcpy\arcpy\management.py", line 4230, in CalculateField
raise e
File "c:\program files\arcgis\pro\Resources\arcpy\arcpy\management.py", line 4227, in CalculateField
retval = convertArcObjectToPythonObject(gp.CalculateField_management(*gp_fixargs((in_table, field, expression, expression_type, code_block), True)))
File "c:\program files\arcgis\pro\Resources\arcpy\arcpy\geoprocessing\_base.py", line 506, in <lambda>
return lambda *args: val(*gp_fixargs(args, True))
arcgisscripting.ExecuteError: ERROR 999999: Something unexpected caused the tool to fail. Contact Esri Technical Support (http://esriurl.com/support) to Report a Bug, and refer to the error help for potential solutions or workarounds.
Invalid pointer
Failed to execute (CalculateField).
Is it something with my line of code that is not working?
My goal is to:
Copy the text from the selected feature below:
and put it into the newly created field.
I would really appreciate your help,
Thank you so much!
Natalia
DavidPike
MVP Notable Contributor
For your select query I think OBJECTID should be enclosed in quotes.
select = ' " ' + "OBJECTID" + ' " '  + " = " + str(row[0])
JoshuaBixby
MVP Esteemed Contributor
Although AddFieldDelimiters—ArcPy Functions | ArcGIS Desktop will still add double quotes around file geodatabase and shape file field names, they haven't been necessary for a while.  The ArcMap SQL reference for query expressions used in ArcGIS—Help | ArcGIS for Desktop (ArcMap) documentation states:
For File geodatabase data you can enclose your field names in double quotes, but it's generally not needed.
The ArcGIS Pro SQL reference for query expressions used in ArcGIS—ArcGIS Pro | ArcGIS Desktop (Pro) documentation has gone one step further and completely removed the Fields section so there are no references to field delimiters.
RandyBurton
I don't think arcpy.env.workspace can take "two geoprocessing environments".  Perhaps the comma in the workspace variable is causing the "something unexpected" error.
JoshuaBixby
Randy, I don't think the OP is trying to pass two values, the comma is in the name of the folder!  Although allowed by Windows and ArcGIS, I think most would argue commas are a bad idea in file paths.
RandyBurton
I took another look at your code and was wondering if you intended to create a new field in your parcels layer for each feature in the Merged_Overlays_Layer? This could be a lot of fields to add.  Or did you intend to create a field and populate it with the name/ID of the overlay feature the parcel was located in?
For the CalculateField, I believe the single quotes should be inside the double quotes for the third parameter.
# try instead:
"'Overlay_{}'".format(row[1])
I was experimenting in Desktop and needed to add a 4th parameter "PYTHON_9.3" which is supposed to be optional, but without it I was getting an error.
For my testing I was using the following code in ArcMap's Python window.  Changes are probably required, but it may give you some ideas.
parcels = 'austin_parcels_layer'
pField = 'Overlay' # new field for overlay feature name/ID
overlay = 'Merged_Overlays_layer'
oFields = ['OBJECTID', 'zoning_ove']
arcpy.management.AddField(parcels, pField, 'TEXT', None, 100) # add text field with length of 100
with arcpy.da.SearchCursor(overlay,oFields) as cursor:
    for row in cursor:
        arcpy.management.SelectLayerByAttribute(overlay, "NEW_SELECTION",select)
        arcpy.management.SelectLayerByLocation(parcels, "HAVE_THEIR_CENTER_IN", overlay, "", "NEW_SELECTION")
        arcpy.management.CalculateField(parcels, pField, "'{}'".format(row[1]), "PYTHON_9.3")
arcpy.management.SelectLayerByAttribute(overlay,"CLEAR_SELECTION") # clear any selections
arcpy.management.SelectLayerByAttribute(parcels,"CLEAR_SELECTION")
JoshuaBixby
Your first Select Layer by Attribute is unnecessary and may cause issues if you are changing the selection of a layer while iterating over the layer with a Search Cursor.  Just add "SHAPE@" to your list of field names to get the shape you are interested in and drop the first Select Layer By Attribute.
Do you really want to add a new field for each loop in the Search Cursor?  Assuming austin_parcel_layer geometries can only have their center in one merged_overlays_layer, you will be creating an unnecessarily sparse matrix of columns and rows.
NataliaGutierrez1
Hi Joshua, Randy and David,
Thanks for your help!
I did need to add a new field for each loop in the Search Cursor.
This is the code that ended up working. I am sharing it just in case anyone needs it.
I had to fix some of the raw data for it to work correctly. I had to modify the names of the cell values to have underscores instead of spaces.
Import arcpy
arcpy.env.workspace = r"D:\APRX_MXDS\Geo_Engine_Zoning_Project\Austin_Geo_Engine.gdb"
    for row in cursor:
        arcpy.management.CalculateField("austin_parcels_layer", "Overlay_{}".format(row[1]), "'Overlay_{}'".format(row[1]), "PYTHON_3")
arcpy.management.SelectLayerByAttribute("Merged_Overlays_Layer", "CLEAR_SELECTION") # clear any selections
arcpy.management.SelectLayerByAttribute("austin_parcels_layer", "CLEAR_SELECTION")
RandyBurton
Thanks Joshua Bixby for the comment about using "SHAPE@".   The SelectLayerByAttribute step is not necessary.
oFields = ['OBJECTID', 'zoning_ove', 'SHAPE@']
    for row in cursor:
        print "Processing feature {}".format(row[0])
        arcpy.management.SelectLayerByLocation(parcels, "HAVE_THEIR_CENTER_IN", row[2], "", "NEW_SELECTION") # row[2] is SHAPE@
        arcpy.management.CalculateField(parcels, pField, "'{}'".format(row[1]), "PYTHON_9.3")‍‍‍‍‍‍‍
JoeBorgione
Do what all those guys suggest....
