Iterate through features and select by location
5762
11
03-05-2020 03:34 PM
NataliaGutierrez1
I have a layer with Zoning Overlays. I have a layer with parcels. I need to iterate through zoning Overlay, select the parcels falling inside, add a new field to the parcels Feature class and add some text to the selected fields, then repeat for the next zoning overlay. The loop works, insofar but it stops with a particular error that is not specific enough.
The code runs until it has to assign the values to the second field.
Please see below for more details.
Here's my code:
Import arcpy
# Set two geoprocessing environments
arcpy.env.workspace = r"D:\APRX, MXDS\Geo_Engine_Zoning_Project\Austin_Geo_Engine.gdb"
# List of fields in Merged_Ovelays FC
fields = ["OBJECTID", "zoning_ove"]
# Convert austin_parcels feature class to feature layer
arcpy.MakeFeatureLayer_management("austin_parcels", "austin_parcels_layer")
# Convert Merged_Overlays feature class to feature layer
arcpy.MakeFeatureLayer_management("Merged_Overlays", "Merged_Overlays_Layer")
# arcpy.da.SearchCursor(in_table, field_names, {where_clause}, {spatial_reference}, {explode_to_points}, {sql_clause})
with arcpy.da.SearchCursor("Merged_Overlays_Layer", fields) as cursor:
    for row in cursor:
        select = "OBJECTID = {}".format(row[0])
# SelectLayerByAttribute(in_layer_or_view, {selection_type}, {where_clause}, {invert_where_clause})
        arcpy.management.SelectLayerByAttribute("Merged_Overlays_Layer", "NEW_SELECTION", select)
# SelectLayerByLocation(in_layer, {overlap_type}, {select_features}, {search_distance}, {selection_type}, {invert_spatial_relationship})
        arcpy.management.SelectLayerByLocation("austin_parcels_layer", "HAVE_THEIR_CENTER_IN", "Merged_Overlays_Layer","","NEW_SELECTION")
# Syntax: AddField(in_table, field_name, field_type, {field_precision}, {field_scale}, {field_length}, {field_alias}, {field_is_nullable}, {field_is_required}, {field_domain})
        arcpy.management.AddField('austin_parcels_layer', "Overlay_{}".format(row[1]), "TEXT")
# CalculateField(in_table, field, expression, {expression_type}, {code_block}, {field_type})
        arcpy.management.CalculateField("austin_parcels_layer", "Overlay_{}".format(row[1]), '"Overlay_{}".format(row[1])')
I am getting the following error and I am not sure how to fix it:
File "<string>", line 24, in <module>
File "c:\program files\arcgis\pro\Resources\arcpy\arcpy\management.py", line 4230, in CalculateField
raise e
File "c:\program files\arcgis\pro\Resources\arcpy\arcpy\management.py", line 4227, in CalculateField
retval = convertArcObjectToPythonObject(gp.CalculateField_management(*gp_fixargs((in_table, field, expression, expression_type, code_block), True)))
File "c:\program files\arcgis\pro\Resources\arcpy\arcpy\geoprocessing\_base.py", line 506, in <lambda>
return lambda *args: val(*gp_fixargs(args, True))
arcgisscripting.ExecuteError: ERROR 999999: Something unexpected caused the tool to fail. Contact Esri Technical Support (http://esriurl.com/support) to Report a Bug, and refer to the error help for potential solutions or workarounds.
Invalid pointer
Failed to execute (CalculateField).
Is it something with my line of code that is not working?
My goal is to:
Copy the text from the selected feature below:
and put it into the newly created field.
I would really appreciate your help,
Thank you so much!
Natalia
NataliaGutierrez1
Thank you!
JoeBorgione
These guys are my go-to python compradres (along with Dan Patterson‌) and all of them have younger eyes and could read your code better than I could!
