Save/cache answers of repeats
991
03-01-2020 05:17 PM
MarcoPoetsch
Hi all,
I created a Survey123 with repeats. So far so good, however, I'm wondering if its posisble to save/cache values from one repeat to the next one?
So e.g.
If in repeat 1 of field A the answer = "ABC", in the repeat 2 of field A the answer should be by default "ABC"
DO you know if this is technically possible? That would be a huge help for the field workers
Tags (3)
DougBrowning
MVP Esteemed Contributor
See this post from a few days ago.  It is asked for a lot but you cannot do it.  I have a workaround that helps us.  Hopefully it will help you.
https://community.esri.com/thread/248761-is-it-possible-to-auto-populate-answers-in-repeats-from-pre...
DougBrowning
