Is it possible to auto populate answers in repeats from previous a repeat in the same survey?
1823
02-24-2020 10:53 AM
ChristopheFarnault
Hi everyone,
I have a survey within Survey123 that has a repeat of questions that a user will enter numerous times while completing a survey. For each set of repeat questions, most of the inputs will be the same for a given day. Rather than having to enter the data manually for each field when a repeat is created, is it possible to copy the inputs from the previous set of questions in the repeat to save time entering inputs that will be the same?
Any help or suggestions will be greatly appreciated.
Thank you,
Christophe
JamesTedrick
Esri Esteemed Contributor
Hi Christophe,
This currently isn't available out of the box with Survey123.  It may be possible using a beta feature (custom JavaScript functions).
ChristopheFarnault
Thank you, James. i appreciate the quick response.
DougBrowning
MVP Esteemed Contributor
I came up with a way using a Defaults page.  See my post here.  Crew loves it.
https://community.esri.com/thread/205999-is-it-possible-to-auto-populate-previous-data-into-current-...
ChristopheFarnault
Thanks for the feedback Doug. I will look into your work around with a default page...
