Arcpy - ExportToPDF - output_as_image
2899
12-05-2019 11:27 AM
PatrickTighe
According to the Docs on Esri's website for the Layout (and mapSeries) class, there is supposed to be parameter for the "exportToPDF" function called "output_as_image", but when running code including that parameter (both in IDLE and in the python window of ArcPro) arcpy gives the "Unexpected keyword argument" error.
Is this is a versioning issue where I need to update my version of Pro to the newest? I don't see anything in the changelog referencing the addition of this keyword in the exportToPDF functions.
DanPatterson_Retired
I suspect the docs are for the most recent versions
import arcgis
arcgis.__version__
Out[9]: '1.7.0'
What does yours report
PatrickTighe
well that was easy! My install of Arc Pro 2.3.1 has arcgis version 1.5.1. Is there any way to update the arcgis library without updating the ArcPro program? My IT is reluctant to update because it'd mean updating/being different from everyone's installations (according to them)
Sorry... When I worked, our IT department made sure that we had the necessary tools to do our job... being different wasn't an issue
BTW
That version is all but dead... Give someone the heads-up, they have a little bit less than a year to go
Esri Support ArcMap 10.3 (10.3.1)
