Export training data for deep learning
5563
14
11-05-2019 03:00 AM
MattiasTivlin
Hi all!
I'm trying to learn about python and deep learning. I have tried to follow the sample notebooks and watch the training courses but now i'm stucked.
I have done some training samples in Arcgis Pro with the training samples manager and saved it as a shapefile.
Then i export the samples with GP-tool "Export Training Data For Deep Learning" with KITTI Labels as Meta Data Format.
In jupyter notebook i write this to load the samples
from arcgis.learn import prepare_data
data = prepare_data('Path to my samples')
data.show_batch
The error i get
~\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone4\lib\site-packages\arcgis\learn\_data.py in prepare_data(path, class_mapping, chip_size, val_split_pct, batch_size, transforms, collate_fn, seed, dataset_type, resize_to, **kwargs)
572 return ner_prepare_data(dataset_type=dataset_type, path=path, class_mapping=class_mapping, val_split_pct=val_split_pct)
573 else:
--> 574 raise NotImplementedError('Unknown dataset_type="{}".'.format(dataset_type))
575
576 if dataset_type == 'RCNN_Masks':
NotImplementedError: Unknown dataset_type="KITTI_rectangles".
What am i doing wrong?
Regards Mattias
DanPatterson_Retired
The error suggests that the details are to the path name you used.  If it was a shapefile did you add the *.shp file extension?  In any event more information on the file type and path name are needed
MattiasTivlin
Here's the export tool and to the right is the folders with images that was created.
data = prepare_data('Output Folder/chips') so how should prepare_data look like?
MattiasTivlin
you might want to try it through the python interface.  The warning beside the output folder name suggests something is amiss
Export Training Data For Deep Learning—Help | ArcGIS Desktop
MattiasTivlin
I exported the training data via python interface but i got the same error when preparing data
by Anonymous User
Not applicable
Mattias Tivlin‌ what kind of deep learning task do you want to do ? If it is an object detection task, you can try exporting data in the format 'pascal voc objects'.
Javier_AntonioEscudero
Hi Mattias
  • Try to use metadata mode PASCAL VOC rectangles instead of KITTY rectangles.
  • Use PNG Format.
  • Replace all commas to points for each file in labels folder.
That worked for me.
Javier Escudero
MattiasTivlin
Great! I will try that
MattiasTivlin
Its working now
Changed the comma to Points. Thank you so much for the help
