Survey123 Webhooks missing from Microsoft Flow
6309
17
09-19-2018 01:19 AM
niklasGregersen
Hi Geonet
Do I need to trigger something before I can set up the new webhooks for Survey123 with Microsoft Flow? When I search for Survey123 I get no options. Do anyone have the same issue?
Best regards Niklas
JamesTedrick
Esri Esteemed Contributor
Hi Niklas,
You should be able to see the Survey123 connector.  Just to check, which region are you using Flow in (Regions overview for Microsoft Flow - Microsoft Flow | Microsoft Docs )?
niklasGregersen
Hi James
Yep it is weird. I am using it in Europe.
MeganCampe
James Tedrick I am also unable to see the Survey123 connector, my region is set to United States.
MeganCampe
Hi James, is there an update on when the Survey123 connector will be available in Flow again?
JamesTedrick
Hi Megan,
The Survey123 connector is available in Microsoft Flow.  You should be able to use 'Create from blank', 'Search from hundreds of connectors and triggers' and type in Survey123 and see it in the results:
Survey123 Connector in Microsoft Flow
MeganCampe
Hi James,
Below is a screenshot of what I see when searching for the Survey123 connector. Are there any additional steps required to access the connector that are not listed in this set up page: https://community.esri.com/groups/survey123/blog/2018/07/19/automating-workflows-with-survey123-and-... ?
niklasGregersen
Hi James
I keep having the same issue as Megan, with no Survey123 connector when I search for it under 'add a trigger'. Is there something else that we need to configure to access it?
TKSHEP
I am also not showing the survey123 connector or trigger in the US version of flow.
RogerDiercks1
I'm having the same issue with the Survey123 connector seemingly missing from the US version of Flow.
