Return Attributes to HTML DIV
6298
27
08-31-2018 06:33 AM
jaykapalczynski
Honored Contributor
Ideas on how to modify this example to return at least one attribute from the layers into an html DIV instead of the length or Count of selected features.
ArcGIS API for JavaScript Sandbox
Preferable I would like:
1. To return attributes values for each record into an HTML Div Tag.
2. Be able to select the graphic and highlight the table record
3. Be able to click the table record and highlight the feature in the map
Anyone have a basic example of this?
Click Map, Create Buffer for selection, Return results into controlled DIV tag, Have interaction between the map and the table of results.
RobertScheitlin__GISP
Jay,
   There is not going to be sample for everything you want to do sometimes you have to merge two samples like this then.
<!DOCTYPE html>
<html>
<head>
  <meta charset="utf-8">
  <title>Map with a Dojo dGrid</title>
  <link rel="stylesheet" href="http://js.arcgis.com/3.25/dojo/resources/dojo.css">
  <link rel="stylesheet" href="http://js.arcgis.com/3.25/dgrid/css/dgrid.css">
  <link rel="stylesheet" href="http://js.arcgis.com/3.25/dgrid/css/skins/tundra.css">
  <link rel="stylesheet" href="http://js.arcgis.com/3.25/dijit/themes/tundra/tundra.css">
  <link rel="stylesheet" href="http://js.arcgis.com/3.25/esri/css/esri.css">
  <style>
    html,
    body {
      height: 100%;
      width: 100%;
      margin: 0;
      padding: 0;
      overflow: hidden;
    #container {
      height: 100%;
      visibility: hidden;
    #bottomPane {
      height: 200px;
    #grid {
      height: 100%;
    .dgrid {
      border: none;
    .field-id {
      cursor: pointer;
  </style>
  <script src="http://js.arcgis.com/3.25/"></script>
  <script>
    // load dgrid, esri and dojo modules
    // create the grid and the map
    // then parse the dijit layout dijits
    require([
      "dgrid/OnDemandGrid",
      "dgrid/Selection",
      "dojo/store/Memory",
      "dojo/_base/array",
      "dojo/dom-style",
      "dijit/registry",
      "esri/map",
      "esri/layers/FeatureLayer",
      "esri/symbols/SimpleMarkerSymbol",
      "esri/symbols/SimpleLineSymbol",
      "esri/symbols/SimpleFillSymbol",
      "esri/Color",
      "esri/renderers/SimpleRenderer",
      "esri/tasks/QueryTask",
      "esri/tasks/query",
      "esri/geometry/Circle",
      "esri/graphic",
      "esri/dijit/PopupTemplate",
      "esri/InfoTemplate",
      "dojo/_base/declare",
      "dojo/number",
      "dojo/on",
      "dojo/_base/lang",
      "dojo/parser",
      "dijit/layout/BorderContainer",
      "dijit/layout/ContentPane",
      "dojo/domReady!"
    ], function(
      Grid,
      Selection,
      Memory,
      array,
      domStyle,
      registry,
      Map,
      FeatureLayer,
      SimpleMarkerSymbol,
      SimpleLineSymbol,
      SimpleFillSymbol,
      Color,
      SimpleRenderer,
      QueryTask,
      Query,
      Circle,
      Graphic,
      PopupTemplate,
      InfoTemplate,
      declare,
      dojoNum,
      on,
      lang,
      parser
      parser.parse();
      // create the dgrid
      window.grid = new(declare([Grid, Selection]))({
        // use Infinity so that all data is available in the grid
        bufferRows: Infinity,
        columns: {
          "id": "ID",
          "popuplation": {
            "label": "2000 Population",
            "formatter": dojoNum.format
          "households": "Households",
          "houseunits": "House Units"
      }, "grid");
      // add a click listener on the ID column
      grid.on(".field-id:click", selectBlkPnt);
      window.map = new Map("map", {
        basemap: "streets",
        center: [-95.249, 38.954],
        zoom: 14,
      window.blockUrl = "https://sampleserver6.arcgisonline.com/arcgis/rest/services/Census/MapServer/0";
      window.outFields = ["OBJECTID", "POP2000", "HOUSEHOLDS", "HSE_UNITS"];
      var fl = new FeatureLayer(window.blockUrl,{
        outFields: ["*"]
      // Selection symbol used to draw the selected census block points within the buffer polygon
      var symbol = new SimpleMarkerSymbol(
        SimpleMarkerSymbol.STYLE_CIRCLE,
        12,
        new SimpleLineSymbol(
          SimpleLineSymbol.STYLE_NULL,
          new Color([247, 34, 101, 0.9]),
        new Color([207, 34, 171, 0.5])
      fl.setSelectionSymbol(symbol);
      // Make unselected features invisible
      var nullSymbol = new SimpleMarkerSymbol().setSize(0);
      fl.setRenderer(new SimpleRenderer(nullSymbol));
      fl.on("click", selectGrid);
      // change cursor to indicate features are click-able
      fl.on("mouse-over", function() {
        window.mapClickEvt.pause();
        map.setMapCursor("pointer");
      fl.on("mouse-out", function() {
        setTimeout(function(){
          window.mapClickEvt.resume();
        }, 800);
        map.setMapCursor("default");
      map.addLayer(fl);
      var circleSymb = new SimpleFillSymbol(
        SimpleFillSymbol.STYLE_NULL,
          SimpleLineSymbol.STYLE_SHORTDASHDOTDOT,
          new Color([105, 105, 105]),
        ), new Color([255, 255, 0, 0.25])
      var circle;
      // When the map is clicked create a buffer around the click point of the specified distance
        window.mapClickEvt = on.pausable(map, "click", function(evt){
        circle = new Circle({
          center: evt.mapPoint,
          geodesic: true,
          radius: 1,
          radiusUnit: "esriMiles"
        map.graphics.clear();
        var graphic = new Graphic(circle, circleSymb);
        map.graphics.add(graphic);
        var query = new Query();
        query.geometry = circle.getExtent();
        // Use a fast bounding box query. It will only go to the server if bounding box is outside of the visible map.
        fl.queryFeatures(query, selectInBuffer);
      function selectInBuffer(response){
        var feature;
        var features = response.features;
        var inBuffer = [];
        // Filter out features that are not actually in buffer, since we got all points in the buffer's bounding box
        for (var i = 0; i < features.length; i++) {
          feature = features[i];
          if(circle.contains(feature.geometry)){
            inBuffer.push(feature.attributes[fl.objectIdField]);
        query.objectIds = inBuffer;
        // Use an objectIds selection query (should not need to go to the server)
        fl.selectFeatures(query, FeatureLayer.SELECTION_NEW, function(features){
          var data = array.map(features, function(feature) {
            return {
              // property names used here match those used when creating the dgrid
              "id": feature.attributes[window.outFields[0]],
              "popuplation": feature.attributes[window.outFields[1]],
              "households": feature.attributes[window.outFields[2]],
              "houseunits": feature.attributes[window.outFields[3]]
          var memStore = new Memory({
            data: data
          window.grid.set("store", memStore);
      map.on("load", function(evt) {
        // show the border container now that the dijits
        // are rendered and the map has loaded
        domStyle.set(registry.byId("container").domNode, "visibility", "visible");
      // fires when a row in the dgrid is clicked
      function selectBlkPnt(e) {
        var fl = map.getLayer("blockPnts");
        query.objectIds = [parseInt(e.target.innerHTML, 10)];
        query.returnGeometry=true;
        fl.queryFeatures(query, function(results){
          var gra = results.features[0].clone();
            12,
              new Color([247, 247, 0, 1]),
            new Color([247, 247, 0, 0.9])
          gra.setSymbol(symbol);
          map.graphics.add(gra);
      // fires when a feature on the map is clicked
      function selectGrid(e) {
        var id = e.graphic.attributes.OBJECTID;
        // select the corresponding row in the grid
        // and make sure it is in view
        grid.clearSelection();
        grid.select(id);
        grid.row(id).element.scrollIntoView();
  </script>
</head>
<body class="tundra">
  <div id="container" data-dojo-type="dijit/layout/BorderContainer" data-dojo-props="design: 'headline', gutters: false">
    <div id="map" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region: 'center'"></div>
    <div id="bottomPane" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region: 'bottom'">
      <div id="grid"></div>
    </div>
  </div>
</body>
</html>
Jay,
  This sample sounds like what you are looking for:
https://developers.arcgis.com/javascript/3/sandbox/sandbox.html?sample=fl_dgrid
jaykapalczynski
Honored Contributor
Yea thats sort of what I want....although I want to click an area, draw a buffer and then select the features within the buffer and return those results to the table.  might have to piece a few examples together...just wondering if there was a simple one layer example there already
maybe simply passing the selected features to the query fro the table?
Jay,
<!DOCTYPE html>
<html>
<head>
  <style>
    html,
    body {
      height: 100%;
      width: 100%;
      margin: 0;
      padding: 0;
      overflow: hidden;
    #container {
      height: 100%;
      visibility: hidden;
    #bottomPane {
      height: 200px;
    #grid {
      height: 100%;
    .dgrid {
      border: none;
    .field-id {
      cursor: pointer;
  </style>
  <script>
    require([
      "dgrid/Selection",
      "dojo/_base/array",
      "dojo/dom-style",
      "dijit/registry",
      "esri/map",
      "esri/Color",
      "esri/tasks/query",
      "esri/graphic",
      "dojo/number",
      "dojo/on",
      "dojo/_base/lang",
      "dojo/parser",
      "dojo/domReady!"
    ], function(
      Grid,
      Selection,
      Memory,
      array,
      domStyle,
      registry,
      Map,
      FeatureLayer,
      SimpleMarkerSymbol,
      SimpleLineSymbol,
      SimpleFillSymbol,
      Color,
      SimpleRenderer,
      QueryTask,
      Query,
      Circle,
      Graphic,
      PopupTemplate,
      InfoTemplate,
      declare,
      dojoNum,
      on,
      lang,
      parser
      parser.parse();
      // create the dgrid
        columns: {
          "id": "ID",
          "popuplation": {
      }, "grid");
        basemap: "streets",
        zoom: 14,
        outFields: ["*"]
        12,
        }, 800);
      map.addLayer(fl);
      var circle;
          geodesic: true,
          radius: 1,
        var feature;
        var inBuffer = [];
            return {
            data: data
            12,
        grid.select(id);
  </script>
</head>
    </div>
  </div>
</body>
</html>
jaykapalczynski
Honored Contributor
I was just merging two examples and then checked this....cool to see I was on the correct path and solution...
I was literally just merging the below that you referenced above
THANK YOU FOR YOUR HELP and conformation.....
 return {
    "id": feature.attributes[WMAoutFields[0]],
    "TYPE": feature.attributes[WMAoutFields[1]],
    "WMA": feature.attributes[WMAoutFields[2]],
    "FG_Symbol": feature.attributes[WMAoutFields[3]]
    data: data
Don't forget to mark this question as answered by clicking on the "Mark Correct" link on the reply that answered your question.
jaykapalczynski
Honored Contributor
Pretty puzzled...Can only get index 0 and 1 to return results....grid names same as code above, values exist in these fields...hmmmmm  But for another day.
jaykapalczynski
Honored Contributor
I am really perplexed....It appears that attributes are not being pushed into the buffer...I am definin 6 attributes and have those set in the outfields.....onyl 3 are bein pushed to the alert I set up
When  do this : alert(JSON.stringify(data));
I get this:  missing attributes...0, 2 and 4 are coming through  - 3, 5, and 6 are for some reason not coming through
Any thoughts?
var grid = new (declare([Grid, Selection]))({
   loadingMessage: 'Loading data...',
   noDataMessage: 'No results found.',
    subRows:[
       {field:"ID", label: "ID", rowSpan: 2},
       {field:"TYPE", label: "TYPE"},
       {field:"WMA", label: "WMA" }
       {field:"Rotate_Val", label: "Rotate_Val"},
       {field:"FG_Symbol", label:  "FG_Symbol"},
       {field:"Lat", label:  "Lat"}
}, "grid");
grid.on(".field-ID:click", selectState);
// SNIP
WMAUrl = "https://xxxx/arcgis/rest/services/Projects/Locations/MapServer/2"";
outFields2 = ["OBJECTID", "ID", "TYPE", "WMA", "Rotate_Val", "FG_Symbol ", "Lat"]
var featureLayer = new FeatureLayer("https://xxxx/arcgis/rest/services/Projects/Locations/MapServer/2", {
   mode: FeatureLayer.MODE_SNAPSHOT,
   outfields: ["*"],
   visible: true
//SNIP
        map.on("click", function(evt){
            geodesic: true,
            radius: 1,
          featureLayer.queryFeatures(query, selectInBuffer);
          var feature;
          var inBuffer = [];
              inBuffer.push(feature.attributes[featureLayer.objectIdField]);
          featureLayer.selectFeatures(query, FeatureLayer.SELECTION_NEW, function(results){
          return {
            "ID": feature.attributes[outFields2[0]],
                  "TYPE": feature.attributes[outFields2[2]],
            "WMA": feature.attributes[outFields2[3]],
            "Rotate_Val": feature.attributes[outFields2[4]],
                  "FG_Symbol": feature.attributes[outFields2[5]],
            "Lat": feature.attributes[outFields2[6]]
             data: data
jaykapalczynski
Honored Contributor
OK I added my data calls into your example and it works....have to go back and figure out why my code is not working....considered this solved...
jaykapalczynski
Honored Contributor
I do have one last question..I posted it in this area because it directly deals with my past issues above....while it is working.....I changed this to a line feature and assume that the selection symbology has to be modified to render the line...have issues with that.
If I dont put this code in there to mark the unseelected as O width the lines draw.  NO big deal
var nullSymbol = new SimpleLineSymbol().setWidth(0);
linefl.setRenderer(new SimpleRenderer(nullSymbol));
When I click in the map the features are returned and displayed in the dGrid.  Great
When I click on a record  the grid the feature highlights on the map.                 Great
My issue is when I click the map and the features are selected they are supposed to turn a purpleish color.
This worked for the points but I think I have something wrong with the lines...I have interaction between the grid and map, the features are being selected but the selected features are not rendering in the map for some reason....the only thing I can think of is a bad symbology definition.
      window.grid2 = new(declare([Grid, Selection]))({
               subRows:[
                         {field:"id", label: "ID", rowSpan: 2},
                         {field:"TYPE", label: "type"},
                         {field:"WMA", label: "wma" }
                         {field:"Label", label: "Label"},
                         {field:"Name", label:  "Name"}
      }, "grid2");
      grid2.on(".field-id:click", selectLines);
//-------SNIP---------------------------------------------------------------------
      window.LineUrl = "https://xxxxxx/arcgis/rest/services/Projects/Locations/FeatureServer/4";
      window.LineoutFields = ["OBJECTID", "ID", "Type", "WMA", "Label", "Name"];
      var linefl = new FeatureLayer(window.LineUrl,{
        outFields: ["*"]
      // Selection symbol used to draw the selected lines
   var symbol = new SimpleLineSymbol(
        SimpleLineSymbol.STYLE_Solid,
        3,
     linefl.setSelectionSymbol(symbol);
      linefl.on("click", selectlinefl);
      linefl.on("mouse-over", function() {
      linefl.on("mouse-out", function() {
        }, 800);
      map.addLayer(linefl);
//-------SNIP - ---------------------------------------------------------------------
  function selectInBufferLines(response){
     alert("SelectInBufferLines");
        var feature;
        var inBuffer = [];
            inBuffer.push(feature.attributes[linefl.objectIdField]);
        linefl.selectFeatures(query, FeatureLayer.SELECTION_NEW, function(features2){
            return {
              "id": feature.attributes[LineoutFields[0]],
              "TYPE": feature.attributes[LineoutFields[2]],
              "WMA": feature.attributes[LineoutFields[3]],
              "Label": feature.attributes[LineoutFields[4]],
              "Name": feature.attributes[LineoutFields[5]]
            data: data
          grid2.set("store", memStore);
      function selectLines(e) {
        var fl2 = map.getLayer("LinePnts");
        fl2.queryFeatures(query, function(results){
               SimpleLineSymbol.STYLE_SOLID,
               new Color([247,247,0,.9]),
               5
      function selectlinefl(e) {
        grid2.clearSelection();
        grid2.select(id);
        grid2.row(id).element.scrollIntoView();
