Create Space Time Cube tool not working
5472
11
08-14-2018 10:34 AM
NasserSharareh1
When I click on the "Create Space Time Cube" tool, it doesn't open it. Although other tools like "Optimized Hot Spot Analysis" works fine. What might be the problem?
Tags (1)
DanPatterson_Retired
you don't specify which software..
All are fine in Pro
NasserSharareh1
I use ArcGIS Desktop 10.5.1. I double checked and still doesn't work!
Although, the extensions are installed.
installed is one thing... did you go to Customize, Extensions and if it is a separate extension, then it needs to be toggled on
NasserSharareh1
Yes, that's checked as well . I think it is a software issue!
Well fire up Pro.. it works there and you should have access to it.
So few people are working in that area that I can't think of anyone at esri to flag at present who might be still working with ArcMap.... sorry
NasserSharareh1
So I got the ArcGIS Pro, and it opens the tool. However, when I try to run it, I get this error: Error 001022: This tool requires a projected coordinate system.
I have defined both "Current XY" and "Current Z" coordinate of the map_GCS North American 1983 and NAD 1983 respectively_ so I have no idea why I get this error again and again. Do you have any idea?
if you used the "Define Projection" tool, that is incorrect, you have to use the "Project" tool
NasserSharareh1
At first, I right clicked the map and in the properties and coordinate system tab, I chose those coordinate systems.
But now, I used the "Project" Tool and chose the "Current Map" for the output coordinate system. But, doesn't work either.
the question remains, is the file in a projected coordinate system?  Check the file's properties and examine the 'extent' if the extent looks like it has big numbers and not those like one would expect with decimal degree data, then it is probably projected.  If the data are in the range of -180 to 180 and -90 and 90, then it is not projected.
If you can rule that out, then the problem lies elsewhere, and since nothing seems to have been of use so far, you might want to await other suggestions
