Create polygons that group certain number of points in ArcGIS
14475
13
06-12-2018 05:13 AM
SlobodanKomatina1
I have about 20000 points and I want to create polygons where each polygon contain 200 points, so there should be 20000/200=100 polygons. I want to do that with ArcGIS 10.4.
SteveLynch
DanPatterson_Retired
What rules are you using for the grouping?
some possibilities...
  •  split the points based on sequential number
  • spatially sort the points then group by sorted idea
  • group based on a distance (this is difficult because getting 200 exactly is nearly impossible, so you would have to iterate and subdivide.
SlobodanKomatina1
I just want these groups to contain 200 points and to touch boundaries like on the example bellow.polygons
The quickest way to do that is to use the selector tool, highlight a selection that you have done, use the field calculator to put in a 'key' value (ie week1, week 2 etc).
In any event, you are going to have to draw the boundary.  If you had to reuse this boundary, then you could produce the boundary layer, then do a select by attribute or spatial join.
If you need them as separate files, then use the Split layer tool if you and advance license... or since you are using an old arcmap Split Layer By Attribute works for all license levels
SlobodanKomatina1
So I guess that this idea is that what I need:
as for sorting, a standard spatial sort isn't going to help.
A radial sort around area centroids might help you identify the closest, but given your layout of the zones you are working with... you would be done doing it manually before you finished fine-tuning that.
I do have tools for radial sort but they are for ArcGIS Pro
This sounds similar to one of your other unclosed threads
https://community.esri.com/thread/206712-how-to-merge-adjacent-polygons-to-one-which-sum-of-attribut...
XanderBakker
Esri Esteemed Contributor
SlobodanKomatina1
Great! That works. Now I just want to create polygons that contain points based on attribute value of each point. Also I need these polygons just to touch boundaries, not to overlap each other.
JoshuaBixby
MVP Esteemed Contributor
SteveLynch
Generate Subset Polygons was launched in ArcGIS Pro 2.1
