I'm using Arcgis api for javascript 4.5, and got following issue after mouse over on the map a few times:
Here's my mouse over handler:
this.config.view.on("pointer-move", (event) => this._pointerMoveHandler(event));
_pointerMoveHandler(event: any) {
// the hitTest() checks to see if any graphics in the view
// intersect the given screen x, y coordinates
this.config.view.hitTest(event)
.then((event) => this._showGraphicTooltip(event))
.otherwise((event) => this._closeToolTipDialog());
Here's MapView source code:
Could anyone please help? It's an urgent issue.
Much appreciated!
Solved! Go to Solution.
It should be sometime this month. The API is available now, but until it's officially released, there could be changes.
This apparently is a bug in hitTest that is fixed in 4.7
Thanks Ken, do you know when 4.7 will be released? My project will go-live soon.
Thanks Ken, hopefully no delays.
