Mapview Bug? - HitTest
2009
04-03-2018 11:28 AM
mingleidi
I'm using Arcgis api for javascript 4.5,  and got following issue after mouse over on the map a few times:
Here's my mouse over handler:
this.config.view.on("pointer-move", (event) => this._pointerMoveHandler(event));
_pointerMoveHandler(event: any) {
// the hitTest() checks to see if any graphics in the view
// intersect the given screen x, y coordinates
this.config.view.hitTest(event)
.then((event) => this._showGraphicTooltip(event))
.otherwise((event) => this._closeToolTipDialog());
Here's MapView source code:
Could anyone please help? It's an urgent issue.
Much appreciated!
KenBuja
MVP Esteemed Contributor
It should be sometime this month. The API is available now, but until it's officially released, there could be changes.
KenBuja
This apparently is a bug in hitTest that is fixed in 4.7
https://community.esri.com/message/759086-4x-hittest-issue
mingleidi
Thanks Ken, do you know when 4.7 will be released? My project will go-live soon.
KenBuja
mingleidi
Thanks Ken, hopefully no delays.
