Add Feature class to Terrain
777
03-28-2018 09:13 AM
RavinHasseea
Hi I am trying to script creating/building a terrain.I am using ArcGIS Desptop 10.2.2
I can create the terrain and add pyramid levels. However it is failing on adding the multipoint feature class to the terrain,
therefore I can't build the terrain. See error message below when run in python window.
This works ok when using the New Terrain Wizard. Any ideas?
I have looked at the post in Adding a feature class to terrain in python but there doesn't seem to have any solution for this either.
arcpy.env.workspace = r'C:\Lidar\Height\output\HEIGHT.gdb\TerrainFDS2'
>>> params = "terrain_pts SHAPE masspoints 1 true false points_embed <None> false"
>>> arcpy.AddFeatureClassToTerrain_3d (r"C:\Lidar\Height\output\HEIGHT.gdb\TerrainFDS2\my_terrain", params)
Runtime error
File "<string>", line 1, in <module>
File "c:\program files (x86)\arcgis\desktop10.2\arcpy\arcpy\ddd.py", line 1895, in AddFeatureClassToTerrain
raise e
RuntimeError: Object: Error in executing tool
Tags (1)
