Javascript API Note getting token wit proxy.
3356
5
02-21-2018 03:25 AM
cadgism
I have configured  proxy and trying to consume a secured layer through proxy in Arcgis javascript.
When I test  the proxy manually i get the response  in web browser. That is to to say,  when I enter the following Url in the broweser it returns a valid token :-
Token:
QBh62mCJxxyyXXyyCCCVVOdfDopSvrUX_4qq7IcMcpz2-U‍‍
  URL :
http://localhost/DotNet/proxy.ashx?http://00.00.00:6080/arcgis/tokens?request=gettoken&username=user&password=123&‍‍‍‍
But through Javascript , gives an error :
 dojo.io.script error Error: Token Required‍‍‍
Javascript :
 esriConfig.defaults.io.proxyUrl = "http://localhost/DotNet/proxy.ashx";
 esri.config.defaults.io.alwaysUseProxy = false;
urlSecuredlayer = "http://00.00.00.00:6080/arcgis/rest/services/myQuery/mylayer/MapServer/0";
Securedlayer = new esri.layers.FeatureLayer(urlSecuredlayer, { id: "urlSecuredlayer", mode: esri.layers.FeatureLayer.MODE_ONDEMAND, outFields: ["*"] });
    tiledLayer1 = new ArcGISTiledMapServiceLayer(urlsatellite, { id: "SatelitteMap" });
    app.map.addLayer(tiledLayer1);
    var states_Symbol = new esri.symbol.SimpleFillSymbol(esri.symbol.SimpleFillSymbol.STYLE_SOLID,
                   new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_SOLID,
                   new dojo.Color([255, 32, 255, 0.35]), 1),
                   new dojo.Color([255, 65, 125, 0.35]));
    urlSecuredlayer.setRenderer(new esri.renderer.SimpleRenderer(states_Symbol));
    app.map.addLayers([Securedlayer]);
Thank you for any help.
RobertScheitlin__GISP
cadegis,
   Do you have a rule in your proxy.config for your
cadgism
Thank You Robert Scheitlin, GISP
My proxy.config file :-
<?xml version="1.0" encoding="utf-8" ?>
<ProxyConfig allowedReferers="*"
          mustMatch="false">
<serverUrls>
<serverUrl url="http://00.00.00.00:6080/arcgis/rest/services/myQuery/mylayer/MapServer/0"
     matchAll="false"
     host="http://localhost/"
     userName="user"
     password="123">
</serverUrl>
</serverUrls>
</ProxyConfig>
<!-- See https://github.com/Esri/resource-proxy for more information -->‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
cadgis,
   Your proxy.config should use a less specific url.
          mustMatch="false">
  <serverUrls>
    <serverUrl url="http://00.00.00.00:6080/arcgis/rest/services/myQuery"
       matchAll="true"
       username="user"
       password="123">
    </serverUrl>
  </serverUrls>
</ProxyConfig>
Also usename is all lower case you had userName.
cadgism
No Luck..Still not working,  producing same error...
cadgism
Solved. The solution was as follow:-
In Arcgis server all my services were configured as " HTTP and HTTPS " ,  when I changed it to "HTTP Only" it worked as it should.
You were right about the " userName" , it should be "username" .
The 'url' did not make any difference.
Thank You , Robert Scheitlin, GISP
