Why does the Coordinate Conversion Tool crashes ArcMap when using the Import table from a CSV?
2387
6
08-09-2017 08:50 AM
VaneiriPatt1
I am exploring the military tools available and have installed these Add-ins to ArcMap. I have tested the coordinate conversion tool with one coordinate at a time. When I go and try to import a csv, ArcMap will crash and close.
Any reasons why? Or workaround?
DanPatterson_Retired
is this the tool? and are your headers present and correct?  A couple sample rows plus header might help
VaneiriPatt1
HI Dan,
Yes, that is the tool. I have one filed where I have the coordinates.
JayantaPoddar
Check if you could work with Convert Coordinate Notation instead.
Think Location
VaneiriPatt1
Hi Jayanta,
I have tried using the Convert Coordinate Notation but I have the coordinates as Military Grid Reference System in one field but have an error.
MelitaKennedy
Esri Notable Contributor
I think you have the input coordinate format wrong. It needs to be set to MGRS, not DD_2. However, you would need to remove at minimum the space between easting and northing values.
16QCQ 56737 43993 -> 16QCQ 5673743993
However, USNG does allow the space, but data should be in the US, and it assumes NAD83.
Supported Notation Formats  (it's Pro doc, but same as ArcGIS Desktop)
Melita
Well you can use one field to define your coordinates, but you will need to make sure that they meet the correct format
http://solutions.arcgis.com/defense/help/military-tools/arcmap/supported-notation-formats.htm
Alternately, it would have been far easier to collect the longitude and latitude values then do the conversion afterwards.  If the data originated from within a gps, then a quick change of display format and redownload would save a lot of time
