Remove Empty Spaces with Field Calculator
3336
08-01-2017 09:18 AM
NickArcher
I have a fields that is populated with correct values, <Null>, and whitespace/empty. The field is of text value with both numbers and letters in the correct values. I want to remove all of the whitespace/empty and replace them with <Null> instead. I am trying to do this with the field calculator and python.
My current prelogic statement is:
def makeNull(unitType):
  if unitType == str():
    return None
And the box below is:
makeNull( !UnitType!)
However when the field is calculated it turns all of the values to <Null> instead of just the whitespace/empty. Any Idea what I am doing wrong?
IanMurray
Honored Contributor
Maybe you only try evaluating empty strings.
  if unitType == "":
    return None
  else:
    return unitType‍‍‍‍‍
IanMurray
Honored Contributor
  if unitType == "":
    return None
  else:
DanPatterson_Retired
#---- snag the fat-fingered space placer ---
a = "    "
a.strip() == ""
Out[9]: True‍‍‍‍
NickArcher
So the problem was I didn't have a else statement. I added in your else statement and it worked. Thanks.
