ERROR - HTTP Error 504: Gateway Time-out
6420
03-29-2017 08:58 PM
AlistairFox
When running the following code we are getting random http gateway time-out errors
replica1 = newRep.replicas.create(replica_name = (featureLayer + "_replica"),
      return_attachments ='true',
      attachments_sync_direction='bidirectional',
      layers='0',
      data_format='filegdb',
      out_path = FilesFromAGOL)
DEBUG:root:ERROR - HTTP Error 504: Gateway Time-out
I am looping through 10 hosted feature layers and the above error is thrown randomly at one of them, sometimes at layer 5 sometimes at layer 10. The same code on the same layers has been running fine. Trying to figure out if is an issue on the ESRI end that is stopping the replica creation all of a sudden.
Any ideas that i can use to test and isolate the timeout source.
Tags (1)
StephanieWendel
Hey Alistair Fox‌!
If you're getting a 504 Gateway timeout error, you're dataset is probably too large to process as a sync request (which is the default) before it times out. Instead you'll want to run this as an async request. Try setting the async parameter to true. See more info in the help on the create replica call here: arcgis.features.managers module — arcgis 1.0.1 documentation
Thanks!
Stephanie
StephanieWendel
Hey Alistair Fox‌!
Thanks!
Stephanie
