Can I use a featureset as input to analyze_patterns.interpolate_points?
3842
5
03-31-2017 11:05 AM
DavidJohnson5
The API guide for interpolate_points for the input_layer parameter mentions "see Feature Input in documentation".  Where do I find that documentation?  More specifically, I'm trying to figure out if I can use featureset as the input layer?  I'm currently getting this error:
---------------------------------------------------------------------------Exception                                 Traceback (most recent call last)<ipython-input-52-ba1e10e3e46c> in <module>()      1 from arcgis.features.analyze_patterns import interpolate_points----> 2 interpolated_sites = interpolate_points(solardatasites_fset, field='jul_ghi') C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\arcgis\features\analyze_patterns.py in interpolate_points(input_layer, field, interpolate_option, output_prediction_error, classification_type, num_classes, class_breaks, bounding_polygon_layer, predict_at_point_layer, output_name, context, gis)    209         predict_at_point_layer,    210         output_name,--> 211         context)C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\arcgis\_impl\tools.py in interpolate_points(self, input_layer, field, interpolate_option, output_prediction_error, classification_type, num_classes, class_breaks, bounding_polygon_layer, predict_at_point_layer, output_name, context)   1322         params = {}   1323 -> 1324         params["inputLayer"] = super()._feature_input(input_layer)   1325         params["field"] = field   1326         if interpolate_option is not None: C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\arcgis\_impl\tools.py in _feature_input(self, input_layer)    381             input_param =  {"url": input_layer_url }    382         else:--> 383             raise Exception("Invalid format of input layer. url string, feature service Item, feature service instance or dict supported")     384      385         return input_param Exception: Invalid format of input layer. url string, feature service Item, feature service instance or dict supported
RohitSingh2
You can construct an in-memory FeatureCollection object and that will work. The format of FeatureCollection is in the Feature Input page.
RohitSingh2
FeatureSets are not supported as input to the feature analysis tools.
The following are supported:
  • URL to feature layers
  • Items of type Feature Layer
  • Items of type Feature Collections
  • FeatureCollection as a Python dictionary
  • FeatureLayer objects
  • FeatureLayerCollection objects - the first layer is used.
The 'Feature Input' reference was to Feature input—ArcGIS REST API: Spatial Analysis Service | ArcGIS for Developers  but we should have it a better place in the Python API doc - thanks for alerting us to this.
DavidJohnson5
Thanks Rohit the quick response!.  Would it be possible to construct an in-memory feature layer object from a FeatureSet to use as the tool input?  If not, can you suggest any alternatives for passing in a subset of points from a feature layer to the tool that does not involve creating a new feature layer item?
RohitSingh2
DavidJohnson5
That works.  Thanks again!
my_featureset = my_flyr.query(where="state='WY'")
from arcgis.features import FeatureCollection
my_fc = FeatureCollection(my_featureset.to_dict())
interpolated_points = interpolate_points(my_fc, field='GHI')
RohitSingh2
All I can say is... "even better" !
