Is there a way to download web map service published by ArcGIS Server if I connect to it as a user?
16796
24
03-18-2017 11:44 AM
lubnanajeh
Hi All,
I couldn’t figure out if is there a way to download web map service published by ArcGIS Server. Kindly note that I interested to do this in case of I connected to ArcGIS Server as a user not a publisher or admin.
Thanks in advance
Best
Tags (1)
JamalNUMAN
Legendary Contributor
Have you already tried standard tools available in ArcGIS?
Jamal Numan
JayantaPoddar
Are you looking to create a local copy (Geodatabase Feature class) of the map service?
In that case, you need to enable Feature Access capability with EXTRACT option enabled while publishing the Map service in ArcGIS Server.
Editor permissions for feature services—Documentation | ArcGIS Enterprise
Think Location
JamalNUMAN
Does this mean that services published from layers stored file geodatabase?
Do you need to have the data stored in enterprise geodatabase to have its extractable from its service? Even though, the extract tool is not working as shown in the screenshots below
Jamal Numan
JayantaPoddar
What about Right-click the layer in TOC > Data > Export Data? Is it working?
Think Location
JamalNUMAN
No such command is available for the service
Jamal Numan
JayantaPoddar
Did you try right-clicking on the layer under "ggg" map service (h.dbo.tt)?
Think Location
JamalNUMAN
it is here but no export in the menu
Jamal Numan
JoëlHempenius3
I just finished building a web page which uses the Extract Operation to prepare a download for the user. It can be configured for your own data in Arcgis Online and is of course free to use. Have a look at my page and the instructions:
Export geo data
-Joël Hempenius.
Languages: JavaScript, Python and Dunglish
JayantaPoddar
I think you can download the layers only if they are published as hosted feature layers.
You will require Portal for ArcGIS (federated and containing a hosted server) or ArcGIS Online to achieve the desired task.
Think Location
