Arcade Text Constant for TextFormatting.NewLine is adding space instead of new line
78661
44
12-22-2016 08:40 AM
CherylHagevik
I am trying to use TextFormatting.NewLine to add a new line to a Label Expression.
In the Playground, I am entering: $feature.name1 + TextFormatting.NewLine + $feature.name2
But the Result is showing a Space instead of a new line:
Am I setting up this expression correctly?
Thanks!
2 Solutions
ScottMoore__Olympia_
Hi Cheryl and George,
From Chris Whitmore: Arcade supports newline, however it is not supported in the map viewer and template apps. It’s a known limitation with the 3.x JSAPI. It will be addressed once the map viewer and configurable apps move to the 4x JSAPI. At this time, we don’t have a solid estimate on when that will be.
I hope this helps.
Scott
FatihDur
In fact using hex code for "\r\n", which is "\x0d\x0a", does add new line to the pop-ups.
GeorgePlumley
Were you able to get this to work? I'm getting a space as well.
I hope this helps.
Scott
JohnPlunkett
Is there a BUG Number for this?
John P
CherylHagevik
Hi John,
There is not a Bug number for this since it is currently just a limitation. We should start seeing support for this when we migrate to the 4x JSAPI, as Scott mentioned. The limitation is mentioned in relation to ArcGIS Online in the following documentation:
Create labels—ArcGIS Online Help | ArcGIS > Labeling considerations
RebeccaBrown
I was just searching for the same solution. It would be really handy with the type of labels we want to place on our water and wastewater mains.
TarigAhmed3
Is there a workaround?  i.e How to add a new line
ashleyhanes
Has then been solved? Or does anyone know of a workaround to add a new line?
deleted-user-amp86F9KgPL3
This is a HUGE limitation for this platform.... love the arcade language but this needs to be addressed soon.
FatihDur
