Arcade Text Constant for TextFormatting.NewLine is adding space instead of new line
78812
44
12-22-2016 08:40 AM
CherylHagevik
I am trying to use TextFormatting.NewLine to add a new line to a Label Expression.
In the Playground, I am entering: $feature.name1 + TextFormatting.NewLine + $feature.name2
But the Result is showing a Space instead of a new line:
Am I setting up this expression correctly?
Thanks!
PatriciaMoehring
Faith:  I added the hex code and the results show the fields separated on 2 lines but when using the expression in the pop-up, it doesn't show on 2 lines.  Am I doing something wrong?
Expression:  $feature.MINORTYPE+"\x0d\x0a"+$feature.LOCATION
Test Result:
MINORTYPE
LOCATION
This is how the pop-up title ends up
Pop Up Image
by Anonymous User
Not applicable
This workaround doesn't seem to work anymore. Does anyone have any other suggestions?
DamonPettitt
I just stumbled across this limitation as well.  I would love to hear if anybody has found a workaround or if ESRI knows when the problem will be fixed.
NathanaelRodd
Major limitation. Esri, please address this soon.
DanielHunter
I believe this has been resolved with ArcGIS Pro 2.3.  I am able to get a stacked label placing my ID field on top of my elevation field using the following Arcade syntax.
$feature.ID + TextFormatting.NewLine + $feature.PAMAP_DEM
DamonPettitt
I thought this was only an issue in ArcGIS Online, which still seems to have the issue...
DanielHunter
You are correct - I skimmed the conversations and replied in haste while looking for the new line syntax - thanks for clarifying
AaronFerrari
It did not work for me until I checked the box for Stack Label, it worked for me. I am using Python Parser in ArcGIS Pro 2.0
[Feature1].lstrip('0') + '\n' + [Feature2].lstrip('0')
deleted-user-1_r2dgYuILKY
Why is this still an issue?
XanderBakker
Esri Esteemed Contributor
It is still an issue since the Web Map is build with the 3.x version of the SDK and this is no longer an issue in version 4.x. Later this year the web map will be ported to 4.x resolving this and other issues, as far as I understand.
