Buffer not accurate
5640
27
12-20-2016 01:16 PM
by Anonymous User
Not applicable
Hi all,
I am trying to buffer a road segment 200' on each side but it seems like the buffer is not returning me anything accurate. The buffer on each side is like 520' as it is now. Maybe wkid?
var extent2 = new Extent({
                    "xmin": -121.11087086999999, "ymin": 38.517479534000074, "xmax": -119.95226375799996, "ymax": 39.068026806000034,
                    "spatialReference": { "wkid": 4326 }
                //Map
                map = new Map("map", {
                    basemap: "topo",
                    extent: extent2
featureLayer.selectFeatures(selectQuery, FeatureLayer.SELECTION_NEW, function (targetGeometry) {
                            targetGeometry = graphicsUtils.getGeometries(featureLayer.getSelectedFeatures());
                            console.log(targetGeometry);
                            geometryService.union(targetGeometry, function (geometry) {
                                featureLayer.clearSelection();
                                //Buffer params
                                var params = new BufferParameters();
                                params.distances = [200];
                                params.unit = geometryService.UNIT_FOOT;
                                //Simplify features first
                                geometryService.simplify([geometry], function (simplifiedGeometries) {
                                    params.geometries = simplifiedGeometries;
                                    //do the buffer
                                    geometryService.buffer(params, showBuffer);
                            }, function (err) {
                                console.log(err);
by Anonymous User
Not applicable
I noticed that a similar issue exists on that ESRI sample. I wonder why.
<!DOCTYPE html>
<html>
<head>
<title>Buffer</title>
<link rel="stylesheet" href="https://js.arcgis.com/3.18/dijit/themes/claro/claro.css">
<link rel="stylesheet" href="https://js.arcgis.com/3.18/esri/css/esri.css">
<style>
   html, body {
    height: 100%;
    width: 100%;
    margin: 0;
    padding: 0;
    overflow:hidden;
  #leftPane{
    color:#000;
    width:250px;
    padding-bottom:15px;
  #map{
    padding:0;
  .details{
    font-size:14px;
    font-weight:600;
    padding-bottom:20px;
  button{
    margin:2px;
    cursor:pointer;
</style>
<script src="https://js.arcgis.com/3.18/"></script>
<script>
var map, tb;
require(["dojo/dom",
        "dojo/_base/array",
        "dojo/parser",
        "dojo/query",
        "dojo/on",
        "esri/Color",
        "esri/config",
        "esri/map",
        "esri/graphic",
        "esri/dijit/Measurement",
        "esri/geometry/normalizeUtils",
        "esri/tasks/GeometryService",
        "esri/tasks/BufferParameters",
        "esri/toolbars/draw",
        "esri/symbols/SimpleMarkerSymbol",
        "esri/symbols/SimpleLineSymbol",
        "esri/symbols/SimpleFillSymbol",
        "dijit/layout/BorderContainer",
        "dijit/layout/ContentPane",
        "dijit/form/Button", "dojo/domReady!"
      function(dom, array, parser, query, on, Color, esriConfig, Map, Graphic, Measurement, normalizeUtils, GeometryService, BufferParameters, Draw, SimpleMarkerSymbol, SimpleLineSymbol, SimpleFillSymbol){
        parser.parse();
        esriConfig.defaults.geometryService = new GeometryService("https://utility.arcgisonline.com/ArcGIS/rest/services/Geometry/GeometryServer");
        esriConfig.defaults.io.proxyUrl = "/proxy/";
        esriConfig.defaults.io.alwaysUseProxy = false;
       //Setup button click handlers
        on(dom.byId("clearGraphics"), "click", function(){
          if(map){
            map.graphics.clear();
        //click handler for the draw tool buttons
        query(".tool").on("click", function(evt){
          if(tb){
           tb.activate(evt.target.id);
          basemap: "streets",
          center: [-111.5, 39.541],
          zoom: 7
        var measurement = new Measurement({
          map: map
        }, dom.byId("measurementDiv"));
        measurement.startup();
        map.on("load", initToolbar);
      function initToolbar(evtObj) {
        tb = new Draw(evtObj.map);
        tb.on("draw-end", doBuffer);
      function doBuffer(evtObj) {
        tb.deactivate();
        var geometry = evtObj.geometry, symbol;
        switch (geometry.type) {
           case "point":
             symbol = new SimpleMarkerSymbol(SimpleMarkerSymbol.STYLE_SQUARE, 10, new SimpleLineSymbol(SimpleLineSymbol.STYLE_SOLID, new Color([255,0,0]), 1), new Color([0,255,0,0.25]));
             break;
           case "polyline":
             symbol = new SimpleLineSymbol(SimpleLineSymbol.STYLE_DASH, new Color([255,0,0]), 1);
             break;
           case "polygon":
             symbol = new SimpleFillSymbol(SimpleFillSymbol.STYLE_NONE, new SimpleLineSymbol(SimpleLineSymbol.STYLE_DASHDOT, new Color([255,0,0]), 2), new Color([255,255,0,0.25]));
             break;
          var graphic = new Graphic(geometry, symbol);
          map.graphics.add(graphic);
          //setup the buffer parameters
          params.distances = [ dom.byId("distance").value ];
          params.outSpatialReference = map.spatialReference;
          params.unit = GeometryService[dom.byId("unit").value];
          //normalize the geometry
          normalizeUtils.normalizeCentralMeridian([geometry]).then(function(normalizedGeometries){
            var normalizedGeometry = normalizedGeometries[0];
            if (normalizedGeometry.type === "polygon") {
              //if geometry is a polygon then simplify polygon.  This will make the user drawn polygon topologically correct.
              esriConfig.defaults.geometryService.simplify([normalizedGeometry], function(geometries) {
                params.geometries = geometries;
                esriConfig.defaults.geometryService.buffer(params, showBuffer);
            } else {
              params.geometries = [normalizedGeometry];
        function showBuffer(bufferedGeometries) {
          var symbol = new SimpleFillSymbol(
            SimpleFillSymbol.STYLE_SOLID,
              new Color([255,0,0,0.65]), 2
            new Color([255,0,0,0.35])
          array.forEach(bufferedGeometries, function(geometry) {
</script>
</head>
<body class="claro">
<div data-dojo-type="dijit/layout/BorderContainer"
     data-dojo-props="gutters:'true', design:'sidebar'"
     style="width:100%;height:100%;">
  <div id="map"
       data-dojo-type="dijit/layout/ContentPane"
       data-dojo-props="region:'center'">
  </div>
  <div id="leftPane"
       data-dojo-props="region:'left'">
    <div class="details">Pick a tool and draw on the map. The drawn graphic will be buffered based on the specified parameters.</div>
    <button type="button" class="tool" id="line">Line</button>
    <button type="button" class="tool" id="polyline">Polyline</button>
    <button type="button" class="tool" id="freehandpolyline">Freehand Polyline</button>
    <br/>
    <button type="button" class="tool" id="polygon">Polygon</button>
    <button type="button" class="tool" id="freehandpolygon">Freehand Polygon</button>
    <br/><hr />
    <div><b>Buffer Parameters</b></div>
    Distance:&nbsp;<input type="text" id="distance" size="5" value="25" />
    <select id="unit" style="width:100px;">
      <option value="UNIT_STATUTE_MILE">Miles</option>
      <option value="UNIT_FOOT">Feet</option>
      <option value="UNIT_KILOMETER">Kilometers</option>
      <option value="UNIT_METER">Meters</option>
      <option value="UNIT_NAUTICAL_MILE">Nautical Miles</option>
      <option value="UNIT_US_NAUTICAL_MILE">US Nautical Miles</option>
      <option value="UNIT_DEGREE">Degrees</option>
    </select><br />
    <button type="button" id="clearGraphics">Clear Graphics</button>
    <div id="measurementDiv"></div>
  </div>
</div>
</body>
</html>
RobertScheitlin__GISP
Alex,
  Just add:
params.geodesic = true;
by Anonymous User
Not applicable
That works great with the ESRI sample ! Not too sure why it is not in my
app...
Alex,
   Are you using an esri basemap?
by Anonymous User
Not applicable
Yes.
//Map
                    basemap: "topo"
And the layer I am buffering is wkid 102100  (3857) (WGS84)
Alex,
   In your code you seem to be missing:
by Anonymous User
Not applicable
Still not accurate. strange.
                                //Buffer params
                                    //do the buffer
                            }, function (err) {
                                console.log(err);
Alex,
   The way I have found in my code to keep buffers accurate is to also use:
params.bufferSpatialReference = new SpatialReference({wkid:102003});
by Anonymous User
Not applicable
No luck. I am wondering if the union messes up the buffer
On Tue, Dec 20, 2016 at 2:28 PM, Robert Scheitlin, GISP <geonet@esri.com>
