Buffer not accurate
8702
27
12-20-2016 01:16 PM
by Anonymous User
Not applicable
Hi all,
I am trying to buffer a road segment 200' on each side but it seems like the buffer is not returning me anything accurate. The buffer on each side is like 520' as it is now. Maybe wkid?
var extent2 = new Extent({
                    "xmin": -121.11087086999999, "ymin": 38.517479534000074, "xmax": -119.95226375799996, "ymax": 39.068026806000034,
                    "spatialReference": { "wkid": 4326 }
                //Map
                map = new Map("map", {
                    basemap: "topo",
                    extent: extent2
featureLayer.selectFeatures(selectQuery, FeatureLayer.SELECTION_NEW, function (targetGeometry) {
                            targetGeometry = graphicsUtils.getGeometries(featureLayer.getSelectedFeatures());
                            console.log(targetGeometry);
                            geometryService.union(targetGeometry, function (geometry) {
                                featureLayer.clearSelection();
                                //Buffer params
                                var params = new BufferParameters();
                                params.distances = [200];
                                params.unit = geometryService.UNIT_FOOT;
                                //Simplify features first
                                geometryService.simplify([geometry], function (simplifiedGeometries) {
                                    params.geometries = simplifiedGeometries;
                                    //do the buffer
                                    geometryService.buffer(params, showBuffer);
                            }, function (err) {
                                console.log(err);
by Anonymous User
Not applicable
Thanks for all your help though Robert. It is really appreciated. few more ideas:
-Maybe measure tool is inaccurate?? I dont think so but I am checking. on the map the measurement tool looks good.
-Maybe the targetgeometry variable graphics do not have any SR
                            //targetGeometry = graphicsUtils.getGeometries(featureLayer.getSelectedFeatures());
If nothing works, instead of using a feature layer, I will use QueryTask and Query.
RobertScheitlin__GISP
Alex,
   Was as you do more development you will become accustom to using the developer tools to inspect variables. You can do the basic console.info(targetgeometry); line in your code, or you could place a breakpoint in the code and inspect the var, etc, etc.
by Anonymous User
Not applicable
It seems like the buffer is returned in meters and not feet. That is what I got from testing
DarrenWiens2
So, you get the 200' buffer with:
params.distances = [60.96];
by Anonymous User
Not applicable
Go the issue, instead of:
params2.unit = geometryService.UNIT_FOOT;
use:
params2.unit = GeometryService.UNIT_FOOT;
That was a silly one.
Alex,
   Well chalk it up to a learning experience. CaSe matters in programming.
by Anonymous User
Not applicable
That is definitely a good learning experience right there. I will remember this one... and certainly be more careful about caps letters and lower cases for now on.
by Anonymous User
Not applicable
yes
