Cannot disable routing for a webmap
2752
5
11-14-2016 01:19 PM
DanielleKulas
I've created a webmap and have unchecked 'routing' in the application settings for the webmap. However, the directions button is still visible in the top ribbon of the webmap when I open it.
I logged out of my account, thinking that maybe I can still see the directions tool because I'm an administrator. When I logged in to the same webmap as a user, I was still able to see the directions button and perform the routing function. Again, the routing option in the webmap settings is definitely unchecked.
Is anyone else experiencing a similar issue? Is this a bug? Thanks for any advice.
RussRoberts
Esri Notable Contributor
The routing does not apply to the map viewer. Collector will read that setting and hide the route option.
RussRoberts
DanielleKulas
Ah, I see that now. Thanks!
Is there a way to limit directions at all in the map viewer, since it is my understanding that this function uses credits?
RussRoberts
You can disable users ability to create routes under their roles by un-checking Network Analysis under premium content
DanielleKulas
That makes sense. I assume in the case where I am collaborating with ArcGIS Online members from outside my organization, whose user privileges I can't control, I just need to communicate to not use Network Analysis on the web map in the map viewer.
RussRoberts
Anonymous users do not see the route option. If you are using WAB and have the directions widget you must associate that widget with an organizational account and that will be associated with the credit charge.
