Feature layer hover
8360
12
06-13-2016 08:35 AM
BulbulMajumder1
I visited "Feature layer hover" sample code. It is almost what I am looking for. Only the different what I would like "to hover on objects on the map, instead of area-boundary (as shown in this sample code)". Please help.
AdrianWelsh
MVP Honored Contributor
Hi Bulbul,
It might help if you post the sample link you visited (likely this one: Feature layer hover | ArcGIS API for JavaScript ) and it might be best to post this thread in the ArcGIS API for JavaScript​ place. Community help is for help on the GeoNet.
In any case, have you looked at this code? Does this help?
Show info window on mouse hover | ArcGIS API for JavaScript
BulbulMajumder1
Here is the Link
Please let me know if you need anything else
AdrianWelsh
Thanks, looks like we're on the same page.
Have you looked at this sample code?
BulbulMajumder1
Yes I did but in it you have to click but I just want hover and the geometry of the feature layer is point as this example Feature layer hover | ArcGIS API for JavaScript
here they are using polygon geometry from feature layer and I want point geometry from the feature layer.
AdrianWelsh
Bulbul,
I am not fully sure since I do not know enough about JavaScript. Maybe take a look at these two threads. They may be able to help you:
Popup on hover not working properly
Feature layer hover problem
DavidChrest
I used this same example to hover over a point feature layer.
Just use the name of your Feature Layer.
Instead of southCarolinaCounties.on("mouse-over", function(evt){...
Just do yourPointFeatureLayer.on("mouse-over", function(evt){...
BulbulMajumder1
Thanks David but Its still not working do you mind to have a look in my code thanks
BlakeTerhune
AdrianWelsh
Bulbul,
You can post your code in this thread. It helps if you use the code block like Blake pointed out. (you can also attach a file to this thread but it may be more visual for people to see the code posted as opposed to attached).
