Popup on hover not working properly
5969
6
11-05-2015 10:40 PM
ADITYAKUMAR1
Hi Users,
I followed the example provided in sample to have hover on featurelayer.
Feature layer hover | ArcGIS API for JavaScript
But once I hover on one point I get the popup and when I come back to the same point it does not come.Its coming only once for one point.
And when I remove the mouse from the point, the info window should close, but it does not close.
Any suggestion on this will be helpful.
Aditya Kumar
thejuskambi
Hello Aditya,
I think the map.load event is already executed before you call the maptips function. So I think you should do something like this.
if(map.loaded){
          map.graphics.enableMouseEvents();
          well.on("mouse-out", closeDialog);
else{
map.on("load", function(){
or use the layer-add-result event and make sure you add the layer after seting up the event.
Thejus
AndrewFarrar
Hello Aditya,
Can you post your code?  Otherwise it is hard to diagnose what you are running into.
ADITYAKUMAR1
Here is my code
function maptips() {
well = new esri.layers.FeatureLayer("https://XXXX/arcgis/rest/services/Global/XX/MapServer/3", {
          outFields: ["WELL_NAME", "UWI", "COMMON_NAME", "COUNTRY_NAME", "ORIGINAL_OPERATOR"]
var symbol  = new esri.symbol.PictureMarkerSymbol('http://localhost/map/MapTip.png', 20, 20);
var renderer = new esri.renderer.UniqueValueRenderer(symbol,"WELL_NAME");
well.setRenderer(renderer);
map.addLayer(well);
well.setScaleRange(73957190.948944,18055.954822);
map.infoWindow.resize(245,125);
        dialog = new dijit.TooltipDialog({
          style: "position: absolute; width: 250px; font: normal normal normal 10pt Helvetica;z-index:100"
        dialog.startup();
        var highlightSymbol = new esri.symbol.PictureMarkerSymbol('http://localhost/map/MapTip.png', 20, 20);
        //close the dialog when the mouse leaves the highlight graphic
          map.graphics.on("mouse-out", closeDialog);
        //listen for when the onMouseOver event fires on the countiesGraphicsLayer
        //when fired, create a new graphic with the geometry from the event.graphic and add it to the maps graphics layer
        well.on("mouse-over", function(evt){
          var t = "<b>${WELL_NAME}</b><hr><b>Well Name: </b>${WELL_NAME}<br>"
            + "<b>UWI: </b>${UWI}<br>"
            + "<b>Common Name: </b>${COMMON_NAME}<br>"
            + "<b>Country: </b>${COUNTRY_NAME}";
          var content = esri.substitute(evt.graphic.attributes,t);
          var highlightGraphic = new esri.Graphic(evt.graphic.geometry,highlightSymbol);
          map.graphics.add(highlightGraphic);
          dialog.setContent(content);
          dojo.setStyle(dialog.domNode, "opacity", 0.85);
          dijit.popup.open({
            popup: dialog,
            x: evt.pageX,
            y: evt.pageY
        function closeDialog() {
          map.graphics.clear();
          dijit.popup.close(dialog);
thejuskambi
Hello Aditya,
You are creating the ToolTip dialog on mouse event of FeatureLayer and trying to clear it with the event on map.graphics. which are two different layer.
I suggest you to change map.graphics.on("mouse-out", closeDialog) to well.on("mouse-out", closeDialog)
Hole this helps.
Thejus
ADITYAKUMAR1
Hi Thejus,
I am sorry but its not working.
thejuskambi
Hello Aditya,
if(map.loaded){
else{
Thejus
ADITYAKUMAR1
Hi Thejus,
It really worked.
Thanks a lot.
Aditya Kumar
