Populate Grid - flip rows and columns
5847
11
10-19-2015 02:26 PM
TracySchloss
Honored Contributor
I have two years' worth of county based demographic statistics.
I have the same information for each year.  For example:  totalPopulation, PopulationOver18, Population17_44, Population45_64 etc
On a map click event for the  county layer, I've been asked to display it with years for the columns and rows for the population breakouts,  This format is my question.
I typically use dGrid.  It seems like I can manipulate the data prior to populating it, but I can't quite wrap my brain around how to go about this.
Example:
COUNTY NAME
Statistic
Year 1
Year2
Total Population123145
Population Over 185666
I don't know if this is a true pivot table, or if this is just a 'turning data on it's head' sort of format.
TracySchloss
Honored Contributor
Got it!  I switched to grid.renderArray, as opposed to Memory.  It should work for my purposes.
<!DOCTYPE html>
  <html>
  <head>
    <meta http-equiv="X-UA-Compatible" content="IE=7, IE=9, IE=10">
    <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"/>
    <title>Populate Grid from My Arrays</title>
    <link rel="stylesheet" href="https://js.arcgis.com/3.13/dijit/themes/claro/claro.css"/>
    <link rel="stylesheet" type="text/css" href="https://js.arcgis.com/3.13/esri/css/esri.css"/>
<script type="text/javascript">
var dojoConfig = {
  parseOnLoad: false,
  async:true
</script>
<script type="text/javascript" src="https://js.arcgis.com/3.13compact/"></script>
</head>
<body class="claro">
        require([
        "dojo/on",
        "dojo/parser",
        "dojo/_base/array",
        "dgrid/Grid",
        "dojo/domReady!"
  ], function(
  on, parser,arrayUtils, Grid ) {
        var cols = {fieldName: "Field",val2015:"2015",val2030:"2030"}
        var fields=["Total","Age17_44","Age45_64","Age65_84", "Age85plus"]
        var valCurrent= [1000, 200, 300, 450,350];
        var valEst = [500, 100,200,150, 50]
        var outputArr = [];
          for (index = 0; index < valCurrent.length; index++) {
            var rowObj = {
              fieldName:fields[index],
              val2015:valCurrent[index],
              val2030:valEst[index]
            outputArr.push(rowObj)
      var grid = new Grid({
        columns:cols
        }, "outputGrid");
        grid.renderArray(outputArr);
        grid.startup();
     </script>
        <div id="outputGrid">
      </div>
    </body>
</html>
RickeyFight
Tracy,
I think I understand what you are asking.
You want a way to show in the table the population that is under 18 over 18 but below 50 and so on?
If so what does your data look like?
TracySchloss
Honored Contributor
Not really, no.  This is the kind of data I have and typically you would show you data like this:
FieldValue
CountyCooper
TotalPopulation2015123
TotalPopulation2030145
2015_PopulationUnderAge1718
2030_PopulationUnderAge1715
2015__PopulationAge17_44235
2030_PopulationAge_17_44190
The question is how I can change this format to something more like I showed in my original post.
RickeyFight
Are you opposed to making a new layer?
If not do something like this:
If you are I am not sure how to manipulate the data in Javascript.
SteveCole
Honored Contributor
Obviously you have 2 columns for the years but how many rows are we talking? You might as well create an HTML table & use SPAN tags w/ IDs to just populate the table using element.innerHTML() once you have a map click event. & access to the data values A pain in the butt to initially code but it would work.
TracySchloss
Honored Contributor
The client isn't quite certain about the final rows, but I'd say around a dozen, tops.  I thought about making a plain table, especially since the output format is nothing like how the data will be stored in a table.  Makes it tough to have meaningful events associated with it.
I've used row Renderers before.  I wonder if I could take advantage of that to build a table.  Generally I'm making something that looks like a paragraph with divs, but I guess there's no reason why it couldn't be a table instead as long as I had the HTML format right.
SteveCole
Honored Contributor
HTML Table template:
<table border="1"  cellpadding="3" cellspacing="3">
  <tr>
  <td>County:</td>
  <td>2015</td>
  <td>2030</td>
  </tr>
  <tr>
  <td>Total Population:</td>
  <td><span id="lblPop2015"></span></td>
  <td><span id="lblPop2030"></span></td>
  </tr>
  <tr>
  <td>Population Under 17:</td>
  <td><span id="lblPopUnder17_2015"></span></td>
  <td><span id="lblPopUnder17_2030"</span></td>
  </tr>
  <tr>
  <td>Population 17-44:</td>
  <td><span id="lblPop17_44_2015"></span></td>
  <td><span id="lblPop17_44_2030"></span></td>
  </tr>
</table>
JS:
countyLayer.on("click", function(evt) {
    fullAttrib = evt.attributes;
    document.getElementById("lblPop2015").innerHTML = fullAttrib.TotalPopulation2015;
    document.getElementById("lblPop2030").innerHTML = fullAttrib.TotalPopulation2030;
    document.getElementById("lblPopUnder17_2015").innerHTML = fullAttrib.2015_PopulationUnderAge17;
    document.getElementById("lblPopUnder17_2030").innerHTML = fullAttrib.2030_PopulationUnderAge17;
    //etc etc etc
SteveCole
Honored Contributor
AAAARRRRGGGGHHHH. I *HATE* this stinking forum software.
My HTML got eaten up. Here's a screenshot of what it SHOULD have looked like:
TracySchloss
Honored Contributor
It seems like there's been issues with the forum the past couple of days.  Yesterday I wasn't able to reply to any thread until the end of the day and this AM it was just down.
I'm going to give that a try, along with my renderRow idea.   It seems like I might be able to stuff some of this into an array of fields names and step through it that way.  It would save hard coding all those fields.  If I have to do it that way, it would be manageable, but tedious.    I haven't tried to manipulate the output of the QueryTask with SQL, but then I've never needed to before.
Right now, this is largely a theoretical question.  I don't have the services started up yet to code against while we finalize the specs for this project.  I'll have to remember to come back later and update this post.  I just hate to tell a customer that something is possible, when I've never done it before.
SteveCole
Honored Contributor
My only other random thought was if you could use a SQL query to craft the response from your queryTask in the format you want. I know ESRI typically says "any standard SQL query" works but we all know that's not true..
